![]() | Home > Expedition & Overland > PUMA Dual Battery setup |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4230 ![]() ![]() ![]() |
I've got the stock starter battery with a same physical size leisure battery alongside it under the seat box. I made the battery tray myself as a little project to practise welding. It all fits quite neat with the split charge behind. Obviously it leaves no space for the jack, chock.etc.
I've no photos to hand, but I did post about it on here years ago when I did it if you can be bothered trawling back though.my threads. 2007 110 TDCi Station Wagon XS |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1210 ![]() ![]() |
robbo22, you may be interested in this .....
https://www.ebay.co.uk/itm/126412704698?it...R-r9xpTXYw nothing to do with me, just trying to help a fellow member. |
swt Member Since: 24 Aug 2018 Location: Cumbria Posts: 164 ![]() ![]() ![]() |
Like Bluest, I've got a dual stock battery, which fitted my needs better than a pair of AGMs. Not being up to the welding, I bought a battery retaining plate from GMB. Its a bit pricey, but light and very tough:
https://shop.gmb-mount.de/DEFENDER/Elektrik/Doppelbatteriesys./ With two stock batteries, there is plenty of space at the back of the box for cable entry and a big split charge relay; and at the offside for cables and the like. On the top, there is still enough room for fat cables, inline fuses and a few other bits and bobs (I have a shunt and an insulated bus bar there). The only place where its all a bit tight is the inner side of the box. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
Just got to buy the same as standard battery clamp, 2 M8 nuts and 2 m8 penny washers.
![]() Click image to enlarge No need for fancy expensive battery mounts Instagram @defender_ventures Empire Tuning - Agent |
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 577 ![]() ![]() ![]() |
Dual battery is OK for a permanent camper. I went for a power station, it provides 12V, various USB chargers and 1kW pure sine inverter all in a compact package.
