Home > Series Land Rovers > Half door seal |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 443 |
I can’t remember but I’d put some sealant around the door top bolts ( which I didn’t ) to stop them leaking from around the bolts ( which mine now do)
7th Apr 2024 11:51am |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 595 |
So like this?
Lip to outside and pointing down over edge of door Click image to enlarge Click image to enlarge |
7th Apr 2024 11:57am |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 913 |
I've always done it flat side down, and the lip on the outer edge.
FWIW Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
7th Apr 2024 12:25pm |
Bowbearer Member Since: 12 Aug 2022 Location: Norfolk Posts: 168 |
No that’s the obvious way. It’s a Land Rover.
I thought it was that way round. Recent trip to Dunsfold LR and looked at their series doors. Lip on inside facing down. This is because on the outside you have 2 drain holes for the window channel. If you have the lip on the outside it blocks them. |
4th May 2024 2:01pm |
Thanks for that, I'll give it go this weekend.
5th May 2024 12:36am |
Careful not to overtighten the bolts
They are only held in with a sot weld. Found out the hard way! |
5th May 2024 8:34am |
