Home > My Defender > 1989 Ninety CSW - Update: 8 cylinders
Page 18 of 20 <123 ... 17 181920>
L110CDL
Totally agree with the above reply's Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #1030130 1st Apr 2024 8:37pm
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
Successful bank holiday weekend of painting - Sunday I got the undercoat on:
And then on Monday I got the first coat of top coat put on and I'm really pleased with the results - really nice shine and depth of colour to it, clearly a very high quality paint.
Will be putting another 2 coats on top of this for a nice thick layer and then I'll get on with top coating the doors/bonnet etc. Then the small task of putting it all back together Very Happy
 Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #1030475 4th Apr 2024 11:35am
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
That looks lovely well done Thumbs Up 4.0 V8 Defender 90
My Instagram
Post #1030489 4th Apr 2024 12:49pm
Procta
looking spot on that pal! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1030533 4th Apr 2024 7:34pm
L110CDL
Yep proper job there Bow down 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #1030557 4th Apr 2024 9:15pm
Dinnu
Beautiful finish Thumbs Up Looks like you do not even need to polish Thumbs Up
Sorry if you already mentioned, but what colour is that? Looks great. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1030558 4th Apr 2024 9:16pm
trickster5000
Thanks, it's Arles blue (believe the same as Windjammer blue?) and yes has a good gloss finish straight out of the gun Thumbs Up Matt.
Post #1030799 7th Apr 2024 6:50am
Retroanaconda
Paint looks great. What type is it?
And what kind of spraying setup are you using?
Post #1030807 7th Apr 2024 8:38am
trickster5000
It’s coach enamel paint from Paintman, as linked below. I went for traditional synthetic enamel, gloss finish.
https://paintman.co.uk/shop/land-rover-arles-blue-lrc424/
As for the paint setup it’s nothing fancy really, a small 20 ish litre compressor and a cheap eBay HVLP spray gun (£40 ish). I did most of the prep manually, finishing in 240 grit before priming, then been wet-sanding at around 400 grit between coats where needed. Then just follow the steps as per Paintman’s instructions with regards to thinning and prepping etc.[/url] Matt.
Post #1030855 7th Apr 2024 3:24pm
Retroanaconda
It’s a great finish. I presume it’ll need a lacquer coat for longevity then?
Post #1030874 7th Apr 2024 5:42pm
trickster5000
Paintman do sell a clearcoat but there’s nothing on the website to indicate it’s really necessary. My plan is to just lay 3 decent coats on which should be plenty of thickness to allow for future buffing to keep the shine.
I’ve already tested doing some wet sanding with 1500 grit, then a quick buff and it comes back up to a lovely shine from the dull finish left after sanding so confident with a little bit of effort it’ll stay looking good. The beauty of that is if it ever gets scratched you can just gently sand the scratch out and polish without having to worry about burning through a clear coat. Matt.
Post #1030883 7th Apr 2024 7:05pm
trickster5000
4 coats on, masking tape off Very Happy Big milestone, I can now paint the doors/bonnet and start bolting things on Thumbs Up
 Matt.
Post #1031004 8th Apr 2024 8:29pm
L110CDL
Work of art that is, great job Cool 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #1031008 8th Apr 2024 8:56pm
Procta
looking spot on that pal Thumbs Up
is the damage all fixed now? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1031026 8th Apr 2024 11:17pm
trickster5000
I haven't tackled the squeal on the front corner yet, plan to finish the respray, then strip down the offending hub and inspect wheel bearings etc. Otherwise brake pedal, ignition barrel etc all sorted, just need to refit the plastic shrouds Thumbs Up Matt.
Post #1031259 11th Apr 2024 11:16am
