Home > My Defender > 1989 Ninety CSW - Update: 8 cylinders |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10810 |
Totally agree with the above reply's 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
1st Apr 2024 8:37pm |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 503 |
Successful bank holiday weekend of painting - Sunday I got the undercoat on:
Click image to enlarge And then on Monday I got the first coat of top coat put on and I'm really pleased with the results - really nice shine and depth of colour to it, clearly a very high quality paint. Will be putting another 2 coats on top of this for a nice thick layer and then I'll get on with top coating the doors/bonnet etc. Then the small task of putting it all back together Click image to enlarge Click image to enlarge Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
4th Apr 2024 11:35am |
LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 341 |
That looks lovely well done 4.0 V8 Defender 90
My Instagram |
4th Apr 2024 12:49pm |
Yep proper job there 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
4th Apr 2024 9:15pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3430 |
Beautiful finish Looks like you do not even need to polish
Sorry if you already mentioned, but what colour is that? Looks great. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
4th Apr 2024 9:16pm |
Thanks, it's Arles blue (believe the same as Windjammer blue?) and yes has a good gloss finish straight out of the gun Matt.
7th Apr 2024 6:50am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2656 |
Paint looks great. What type is it?
And what kind of spraying setup are you using? |
7th Apr 2024 8:38am |
It’s coach enamel paint from Paintman, as linked below. I went for traditional synthetic enamel, gloss finish.
https://paintman.co.uk/shop/land-rover-arles-blue-lrc424/ As for the paint setup it’s nothing fancy really, a small 20 ish litre compressor and a cheap eBay HVLP spray gun (£40 ish). I did most of the prep manually, finishing in 240 grit before priming, then been wet-sanding at around 400 grit between coats where needed. Then just follow the steps as per Paintman’s instructions with regards to thinning and prepping etc.[/url] Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
7th Apr 2024 3:24pm |
It’s a great finish. I presume it’ll need a lacquer coat for longevity then?
7th Apr 2024 5:42pm |
Paintman do sell a clearcoat but there’s nothing on the website to indicate it’s really necessary. My plan is to just lay 3 decent coats on which should be plenty of thickness to allow for future buffing to keep the shine.
I’ve already tested doing some wet sanding with 1500 grit, then a quick buff and it comes back up to a lovely shine from the dull finish left after sanding so confident with a little bit of effort it’ll stay looking good. The beauty of that is if it ever gets scratched you can just gently sand the scratch out and polish without having to worry about burning through a clear coat. Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
7th Apr 2024 7:05pm |
4 coats on, masking tape off Big milestone, I can now paint the doors/bonnet and start bolting things on
Click image to enlarge Click image to enlarge Click image to enlarge Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
8th Apr 2024 8:29pm |
Work of art that is, great job 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
8th Apr 2024 8:56pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5203 |
looking spot on that pal
is the damage all fixed now? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
8th Apr 2024 11:17pm |
I haven't tackled the squeal on the front corner yet, plan to finish the respray, then strip down the offending hub and inspect wheel bearings etc. Otherwise brake pedal, ignition barrel etc all sorted, just need to refit the plastic shrouds Matt.
11th Apr 2024 11:16am |
