Home > Td5 > Driver demand problem 1 fault |
Sounds like it is over-boosting. Either sticky waste gate or incorrectly adjusted. Do you have a boost gauge? |
3rd Apr 2024 6:29pm |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 192 |
No, but I have a nanocom, just starting to look at logs now
3rd Apr 2024 7:16pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1648 |
It can be logged sometimes if someone messes with the pedal or pumps it like a looney.
4th Apr 2024 12:16am |
It seems it was, and the cause the waste gate. It built up to 1.33 bar, then drops and wont recover above 1.03 bar until stopped and restarted. Taken the heatshield off this afternoon and waste gate was almost completely solid. now loosened up and the problem seems to have gone. |
4th Apr 2024 5:05pm |
flatfrog Member Since: 04 Mar 2018 Location: East Yorkshire Posts: 5 |
Hi, this may be the same problem - driver demand not responding BUT when started with pedal pressed down it revs like crazy and continues to respond until its allowed to idle, then yellow engine light comes on and stops responding. Is this likley to be the loom or something else - any thoughts? Thanks, Mike
15th Dec 2024 10:08pm |
