Home > Td5 > Driver demand problem 1 fault
Page 2 of 2 <12
geobloke
balmybaldwin wrote:
Can you be more specific with your symptoms? When this occured do you lose power to the extent it won't go beyond idle or is it more like a "Limp mode" that responds to the accelerator, but not very well?
I'm getting the latter symptom particularly on a long hill where the car responds normally until suddenly it doesn't (feels like a limp mode and then can't maintain more than about 60mph. As far as I can tell this is not pedal related as my numbers look normal on the nanocom. I'm yet to look at the wastegate, but a new MAF didn't fix it (old one was def faulty).
Sounds like it is over-boosting. Either sticky waste gate or incorrectly adjusted. Do you have a boost gauge?
Post #1030399 3rd Apr 2024 6:29pm
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
No, but I have a nanocom, just starting to look at logs now
Post #1030415 3rd Apr 2024 7:16pm
Phil68
Just a note that my 'driver demand' fault did not appear straight away. I went looking somewhere else before it appeared in the nanocom.
Post #1030419 3rd Apr 2024 7:24pm
NickMc
It can be logged sometimes if someone messes with the pedal or pumps it like a looney.
Post #1030438 4th Apr 2024 12:16am
balmybaldwin
It seems it was, and the cause the waste gate. It built up to 1.33 bar, then drops and wont recover above 1.03 bar until stopped and restarted.
Taken the heatshield off this afternoon and waste gate was almost completely solid. now loosened up and the problem seems to have gone.
Post #1030515 4th Apr 2024 5:05pm
Page 2 of 2 <12
