![]() | Home > General & Technical (L663) > Matrix led headlights 2020 defender first edition |
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 267 ![]() ![]() |
I think the dealer is telling porkys, if it’s got matrix lights the DRLs should be on . 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 993 ![]() ![]() |
I have a 2020 model and that has NO signature lights
I think the 'S' model came without these lamps. |
Moo Member Since: 01 Oct 2021 Location: Bath Posts: 1254 ![]() ![]() |
Seems odd. I'd check the build spec to make sure it was fitted with Matrix lights. Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
Philm Member Since: 19 Jun 2020 Location: Manchester Posts: 160 ![]() ![]() |
I have a 2020 first edition and the DRL's are on.
the OP question was should matrix lamp also have signature lamps.
there has been much talk on this board of signature lamps failing. Last edited by LR Nuts on 3rd Apr 2024 9:09am. Edited 1 time in total |
Mine are matrix headlamps with signature DRLs, 4 years on and had no problems with them.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2539 ![]() ![]() |
Could it be that a previous owner has turned them off using the GAP tool, maybe after one failed?
Iansjones Member Since: 02 Apr 2024 Location: Stroud Posts: 7 ![]() ![]() |
How can I get hold of the build spec? |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3340 ![]() ![]() |
You sure it’s first edition? if it’s just the side lights that come on then it’s more likely a base model or an S. Do you have a photo or link to the car? 24MY 90 D250 HSE, Tasman Blue
23.5MY 90 D250 X-Dynamic SE, Pangea Green - Gone 22MY 110 D250 XS Edition, Hakuba Silver - Gone 21MY 90 D200 S, Tasman Blue - Gone |
Yes those lights should be on all the time
![]() Click image to enlarge 24MY 90 D250 HSE, Tasman Blue 23.5MY 90 D250 X-Dynamic SE, Pangea Green - Gone 22MY 110 D250 XS Edition, Hakuba Silver - Gone 21MY 90 D200 S, Tasman Blue - Gone |
Many thanks,
It was my thought they should be on. So now to decide do I tell the dealer to sort before delivery. Or wait till I get the car. Check with the iid tool and get sorted under extended lr warrenty Many thanks |
martinf Member Since: 30 Nov 2020 Location: Sussex Posts: 98 ![]() ![]() |
I think that the engine has to be running and the gears out of Park for the DRL's to come on.
It says in the features "matrix headlights with signature DRLs" Get he dealer to correct them before delivery. |
