![]() | Home > Tdi > 200TDi Starting oddities. |
Mining Subsidence Stu Member Since: 06 Mar 2024 Location: Cornwall Posts: 35 ![]() ![]() ![]() |
I've just been out and tried it again. If I turn it to II, the dash lights either come on perfectly, or they don't at all. Then what happens is if I move it slightly to position III, the lights go out or it goes CLICKCLICKCLICKCLICK with the relays. I've waggled everything and now it will crank, but not start.
All of the other electrics are fine. |
Browny90 Member Since: 20 Jul 2015 Location: Derbyshire Posts: 183 ![]() ![]() ![]() |
I have a 200 and I have rebuilt the entire vehicle, but also have been a mechanic for lots of years..
It sounds like you have a bad ignition switch regardless so probably best to start there.. I suppose you could test it by basically joining the wires together on the back (apart from the trigger wire for the starter) that would ensure you have a good connection of the ignition system. similarly, you can ensure you have a god feed to the fuel stop solenoid by just running a wire directly from the batter tot he solenoid. Don't discount that you may have more than one fault, which sometimes injects confusion when diagnosing.. Often when you get odd problems an earth connection can be responsible. I would suggest start from the beginning, and work through logically with each system Electrical Check the battery voltage and charging if you can Check the battery connections and the main wires between the battery, starter and alternator Check the engine/ chassis earth strap (you can test this by fitting a jump lead between the engine and battery/ chassis) As above fit a wire between the battery and the solenoid As above, bypass the ignition switch or just replace it anyway if you have a wobbly key.. Fuel Replace the filter and bleed the system from tank to pump then from pump to injectors Check/ replace the fuel lift pump (very common to fail on these) if you still think its a fuel issue then you need to get eyes in the tank, check the sender and blow the pipes through, check the hoses physically for damage or potential air leaks (they can have holes which draw in air but do not leak fuel.) worst case you can run a hose from a jerry can to the lift pump Mechanical Check the starter motor independently if you can, either remove it and check with jump leads and a trigger wire or do the same while on the vehicle. I think if you run through these you'll find of stumble across the issue(s) Hope thins helps.. Nothing on this list is particularly hard with basic tools.. a multi-meter will help you too if you have one.. Some things are worth replacing anyway as they will fail at some point and it costs more in time to check it that it does to replace, like the fuel filter and the fuel lift pump. My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey ![]() |
In a twist of weird fate (funny fuel gauge). The thing was out of fuel. The test was I wired up the stop solenoid and it clicked and did the same thing.
I have it running now, but I'm going to do the ignition switch whilst I'm at it. Cheers, Stu |
![]() ![]() ![]() Really glad you got to the bottom of it, no harm in doing some of the above anyway after running an empty tank, filter, lift pump and definitely do that ignition switch.. you can probably do that for under £50 My 1986 90 is currently on a full rebuild, with new chassis, Paint etc.. Very much a hybrid, TD5 Chassis, tub & bulkhead with a 200TDI and LT77 GB Painted in Stornoway Grey ![]() |
Oh, it was out of fuel, but in a sick twist of fate, something shat itself ignition wise. Cue me having to wire up the stop solenoid in the supermarket car park.
I got it started on the key and whilst I was driving along, the fuel gauge/petrol gauge etc were all dead. I gave the key a waggle and it came back on. |
For those reading this. The new switch solved all the problems.
......and on the way home the power steering belt shat itself FFFS. Then when I took the lid off the reservoir to see the level, I dropped the cap and it went somewhere that I need ethiopian's arms to get back. |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10955 ![]() ![]() |
That is good news with the problem solved
![]() Sorry to hear with the latter ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
