Home > For Sale & Wanted > [For Sale] 2.4 tdci Defender engine and MT82 gearbox
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
2.4 tdci Defender engine and MT82 gearbox for sale due to a M57 conversion
The engine and box have 99k miles on them.
The bad bits
I had the clutch changed at about 40k miles and again at 89k miles. When it was changed the second time the garage that did the work advised me that they had issues seating the spigot bearing as the end of the crank had been ‘butchered’ when it had been changed before. In the last 10k miles the gearbox has got progressively worse with noise on tick over and the gearbox has become noisy and slack, but was still operational.
The turbo was overheated on an over exuberant rush to a train station and now squeals.
The good bits
The engine comes with a LOF POWERSpec clutch and I can include the ECU that has a Bell Autos remap applied together with their Bluetooth remap tool.
Looking for £1000 for the lot.
Post #1028923 21st Mar 2024 10:09pm
carrotbay
Any offers or suggestions on what’s it’s worth?
Post #1029131 24th Mar 2024 11:13am
rusty_wingnut
How much for the gearbox on it's own?
Post #1029201 25th Mar 2024 9:51am
carrotbay
I’ll pm you
Post #1029204 25th Mar 2024 10:33am
carrotbay
Probably not helping selling the engine, but this the risk of getting a ‘reputable Land Rover independent’ to do work that you don’t get to see for a few years. What a mess!
Sometimes it’s just best to do it yourself and know it’s been done right.
Post #1029223 25th Mar 2024 12:28pm
Co1
Amen to that!
Post #1029232 25th Mar 2024 2:09pm
That's probably why there's little enthusiasm for your engine, if the crank's mullered it's virtually worthless, if the crank's good it has value.
Post #1029264 25th Mar 2024 5:25pm
carrotbay
Yeah, I agree with that now that I’ve seen this. I’m not prepared to deceive anyone which is why I’m being so transparent with the issues with it. I’ll strip it for bits, salvage what I can and scrap the rest.
If anyone needs anything let me know.
Post #1029277 25th Mar 2024 7:09pm
Siwynne
Pm sent
Post #1029278 25th Mar 2024 7:17pm
You could simply split engine and box, then remove the clutch to assess and photograph the damage to the spigot. That way you and any prospective buyer would know the score.
Post #1029281 25th Mar 2024 8:02pm
carrotbay
Blackwolf - the picture above is of the spigot. Someone has been in there with a chisel rather than using the proper route of removing the spigot. I suspect the spigot bearing isn’t seated true which has led to the gearbox bearings getting a hard time.
I would name and shame but it was a long time ago and that business may have changed hands.
Post #1029285 25th Mar 2024 8:43pm
NickMc
I’d take the flywheel off it might not be as bad as it looks, although it looks pretty beat up. I have a good used polished crankshaft if it helps anyone, not hard to swap.
Post #1029287 25th Mar 2024 8:53pm
Oops, how did I miss that! Embarassed
Vandalism Shocked
Post #1029292 25th Mar 2024 9:11pm
Ianh
According to Aulro, https://www.aulro.com/afvb/90-110-130-defe...moval.html. This is the tool for the job, https://www.ebay.com.au/itm/383575022014 . So for circa £12 all that damage could have been avoided !
Plenty of the same generic tool on uk auction site.
Post #1029315 25th Mar 2024 11:31pm
There's also a SP tool for the job if you don't like cheap options!
https://sykes-pickavant.com/products/09584...aring-tool
Absolutely no need for that degree of damage, and it is shockingly bad if it was a "professional" doing the job. If someone did that to mine I'd be after a new engine from them.
Post #1029334 26th Mar 2024 9:20am
