![]() | Home > Puma (Tdci) > Help Water Leaking into Passenger Footwell |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 197 ![]() ![]() ![]() |
Yes, windscreen rubber can be a culprit if cracking at the corners.
Also, the front edge of the door window in the corner where it meets the seal, this can be filled with putty to stop water ingress. Then there is the windscreen frame to bulkhead joint under the the door seal, which should be filled with putty. LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2655 ![]() ![]() ![]() |
Don’t forget the screen to bulkhead blocks.
Mine was leaking into the passenger footwell from there, even though I thought that it couldn’t be because I had changed the gasket the previous year. This time I did use silicone sealant along with new gaskets again. |
sasdiscos Member Since: 22 Jul 2023 Location: UK Posts: 155 ![]() ![]() |
Or like me you could just give up, let it run in and then run out again. 😳
mifa Member Since: 16 Dec 2022 Location: Denmark Posts: 9 ![]() ![]() |
Do you have this for inspiration https://www.landroverweb.com/Pdf-files/Man...Manual.pdf
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
Check clean or remove the air inlet duck bill drains, they fill up with water. There are 3x of them.
When they fill up with tree debris and dirt, water comes in and runs through. I find they are best removed over winter and put back in summer, or just left out. Chillin In The Backwoods🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Two90s Member Since: 24 Dec 2020 Location: Southern UK Posts: 40 ![]() ![]() ![]() |
No I have never seen that book, it is fascinating. In 21 years of Defender ownership. They really can leak from everywhere. Our 300 Tdi leaked from the sunroof and roof seams into the headlining, and when you moved the vehicle it dumped cold water in your lap. It was a nice start to the day. Usually I give up, and let it run out, but this vehicle is too nice. Puma 90 XS Station Wagon in Keswick Green 2012 2.2 Tdci |
Thank you that is a good suggestion, I only found one duck bill drain, it was completely clogged. I did not realise there were others. Puma 90 XS Station Wagon in Keswick Green 2012 2.2 Tdci |
Yes, I used to do that in the 300 Tdi, but the Puma is too nice. Puma 90 XS Station Wagon in Keswick Green 2012 2.2 Tdci |
That is a good call, I will buy some fresh Dum Dum putty on eBay, my old tin of Dum Dum is solid. Puma 90 XS Station Wagon in Keswick Green 2012 2.2 Tdci |
Thank you I will buy some fresh putty. I prefer that to silicone sealant, which always looks messy. (at least when I do it.) Puma 90 XS Station Wagon in Keswick Green 2012 2.2 Tdci |
Millerdark Member Since: 16 Sep 2015 Location: Berkshire Posts: 25 ![]() ![]() ![]() |
Also consider tiger seal and Captain Tolleys.
I have used tiger seal, captain trolleys and dum dum,
as mentioned above all are good products that works. Also, it’s worth checking the windscreen bulkhead blocks, they can leak as well, plus the windscreen screen frame lower to bulkhead foam seal. If it’s the foam seal, then the captain trolleys is probably best, dum dum is okay in corners and entires etc. I would leave the tiger seal as a last option, but it would work. ![]() ⛽️🛢️⚙️🧰💪 |
