Home > Maintenance & Modifications > Diff oil
Naycrx
Diff oil
Lots of research so far....but one question on diff oil, I have used the castrol website to determine the correct oil.
Watching videos, it appears most people just fill the oil in the diffs to the height of the filling plug? Basically till it spills out? Is this OK...given the car will be level
Post #1029030 23rd Mar 2024 1:35am
Mo Murphy
That is the correct way to do it.
50 Shades of Pennine Grey
Post #1029035 23rd Mar 2024 6:54am
Naycrx
great thanks ... Same with the transfer box aswell?
Post #1029036 23rd Mar 2024 7:04am
Dinnu
Yes, also transfer box.
If you have Td5 or earlier, also the main gearbox is fill to spill. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1029037 23rd Mar 2024 7:46am
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
Transfer box and gear box for a Puma are not fill to spill.
Transfer box 2.3 litres required.
Gear box 2.4 litres required.
Post #1029059 23rd Mar 2024 12:42pm
Dinnu
An interesting discussion on transfer box oil capacity vs level on this thread: https://www.defender2.net/forum/topic56771-15.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1029062 23rd Mar 2024 1:25pm
Naycrx
Without wanting to start another new thread.. the
Transfer box breather....found it ... can I just pull the pipe off to check it's clear
Post #1029108 23rd Mar 2024 9:03pm
Jabberwocky
Luxembourg
Make sure you remove the fill plug before the drain plug, not only does it help the oil drain smoothly but you don’t want to drop the oil and then find the filler is seized.
Post #1029111 23rd Mar 2024 9:26pm
^^^^ This, and it’s also a good time to fit magnetic diff plugs if not already fitted too. WeWillWin🇬🇧🇺🇸
Post #1029148 24th Mar 2024 3:33pm
