![]() | Home > Td5 > Defender TD5 Rear washer pump wiring |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 639 ![]() ![]() ![]() |
Did this many years ago on a 2005 90 hardtop that was quite bizarrely factory fitted with full aircon system but no rear wash wipe system or heated rear screen! I seem to remember the washer loom plugged in to the main loom and I may have had to obtain a washer loom with twin plugs, however this was probably fifteen years ago!
110Matty Member Since: 20 Apr 2023 Location: Somerset Posts: 140 ![]() ![]() |
Wow, A/C but no rear wiper or heated screen. I thought mine was a bit strange with aftermarket electric windows and heated electric seats with no rear wiper etc!!
I haven’t been able to find the loom itself yet, will have another go with more enthusiasm now 😊👍 Is there a large main loom connector lurking behind the dash or somewhere (to receive the rear wash look). Thanks for the reply 👍 |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
The rear washer plug is on the LH (UK passenger side) wing loom, right next to the front pump connector.
Front pump is 2 pin red with light green/black and black wires (C0008 below), rear pump is same style connector but black housing with black/light green and black wires (C0021). I believe all the wing looms have the rear washer pump connector on them, there are only two variants which are with/without BBUS and headlamp levelling. Behind the headlight is the best access. ![]() Click image to enlarge ![]() ![]() |
Fantastic, thanks Martin. I’ll probably remove the reservoir anyway, so should be able to find it. 👍
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1674 ![]() ![]() ![]() |
Matty if Martin doesn’t, PaulMc if you look him up has made me looms up before, beautiful work, fairly priced and easy to install.
The reservoir can be a bear to get the screw headed bolts out of, go in through the headlight like in the picture ![]() |
Many thanks Nick.
I’m hoping the loom will be there, but I know where to go now if not 👍 |
oh ok
Hi Martin, found it (I think). Thanks for your replies and knowledge. Do I take it that you do looms if needed? ![]() Click image to enlarge |
Correct connector but wrong wire colours. That’s the alarm sounder connector.
Edit: yes I can and do make up looms ![]() ![]() ![]() |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5235 ![]() ![]() |
martin do you still do the rear wiper loom, that works with the front wipers? We chatted about it some time ago. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
If you mean the little controller which runs the rear on a delay, and in sync with the front, then yes I can still do those
brill martin, where can i get one? i am in back in the market to start throwing upgrades at this.
![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
Hi Martin, I'm hoping to get back onto this, this weekend if I don't take off in the Storm! Interestingly, my alarm still sounds even though i didn't replace this plug anywhere, it felt like it was loose when i discovered it, but it could well have come off from wherever it was attached I suppose. Should the alarm still sound if this connector is loose as it is? |
Found the rear wash pump connector today Martin, it was tucked away. Rear pump installed and working nicely. Cheers for guidance. |
