Home > General & Technical (L663) > Door Blind Spot indicator |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1420 |
My MY2022 SE has the small warning screens on each door to warn about cyclists etc so maybe it was one of the things that got dropped Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
15th Mar 2024 6:40pm |
C&M Member Since: 28 Aug 2020 Location: Hampshire Posts: 185 |
Ian
I have checked my door and I have what looks to be a blank plate near the electric window controls. mine is a MY23 HSE so looks like it was another hit not mentioned by the dealer I am assuming its automatic and you dont have to set it up - grabbing at straws Mark Defender D250 HSE Dender 110 XS - sadly gone VW Polo VW Caravelle - Gen 6 |
15th Mar 2024 8:04pm |
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 269 |
I have it , but I believe it was dropped completely on 23.5. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
15th Mar 2024 8:52pm |
Yes that's where it is on all the doors next to the window switch, no setting up it just works Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
16th Mar 2024 12:03am |
carltb Member Since: 06 Oct 2023 Location: Sweden Posts: 60 |
My 24 model HSE is also missing this feature.
Is it something that is possible/viable to retrofit? Does it run of the same sensors as the regular blindspot assist which I do have? 2025 Defender 130 V8 (DOA, new one coming) 2025 Defender 90 D250 (wifes) 2024 Defender 110 p400e HSE (sold) 2015 Defender 110 Double cab 2004 Defender 90 Td5 |
16th Mar 2024 2:42pm |
I seem to remember (I think) Marco (mmbanf) asked me about it and he looked into retro fitting it but decided against it. Cheers Ian
16th Mar 2024 2:49pm |
The part 14C714 seems to be the thing. But are there connectors for it already in the door is the question...
https://parts.jaguarlandroverclassic.com/p...and-rover/ 2025 Defender 130 V8 (DOA, new one coming) 2025 Defender 90 D250 (wifes) 2024 Defender 110 p400e HSE (sold) 2015 Defender 110 Double cab 2004 Defender 90 Td5 |
16th Mar 2024 3:00pm |
Paladino Member Since: 07 Dec 2022 Location: Serbia Posts: 30 |
The connectors are already in the door. Blind spot indicators are different for the left and right side
19th Mar 2024 8:14am |
inith5 Member Since: 08 Apr 2023 Location: Bavaria Posts: 30 |
I've already thought about retrofitting. The part numbers are LR098327 for the left side and LR098321 for the right side. I also saw something in the CCF list (MultiCAN-680 ClearExitDetectionSystem- Not fitted) but due to lack of time I haven't made any progress with it yet. Thanks to Paladino we now know that the necessary plugs are already there, although we don't know if this is the case for all MJs. What still needs to be clarified is whether the covers for the blind spot indicators have to be changed or whether a suitable hole can be cut in the existing covers so that they can be inserted. 23.5MY Defender 110 D250 HSE
19th Mar 2024 5:13pm |
I can confirm that MultiCAN-680 ClearExitDetectionSystem is marked as Fitted on my CCF
There are also the following settings in the CCF but not sure whether they relate to the same thing MultiCAN-644 SmartExitRrPassDoor Fitted MultiCAN-644 SmartExitRrDrvDoor Fitted MultiCAN-644 SmartExitFntPassDoor Fitted MultiCAN-644 SmartExitFntDrvDr Fitted Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
19th Mar 2024 5:21pm |
Ich habe es auch gesehen und hatte den gleichen Gedanken, ob sie damit zu tun haben
they are set to "not fitted" for me 23.5MY Defender 110 D250 HSE |
19th Mar 2024 5:46pm |
I don't think that you can cut holes - the trim with the clear exit option has the place where you clip the leds. |
19th Mar 2024 10:08pm |
I found 4 sets at a breaker in my country which I ordered. Both new covers with all the correct buttons and switches for my car plus the Clear exit indicator with cable in them already. Total price for all 4 doors less than £170 so worth a try..
Will see how I get on. Hopefully my iid tool g3 can handle the simple coding. Thanks a lot for the CCF info in the thread. The cover piece was what was giving me a headache. Look how many variants there are part <111C92 at https://parts.jaguarlandroverclassic.com/p...and-rover/ Must be 100 different ones... 2025 Defender 130 V8 (DOA, new one coming) 2025 Defender 90 D250 (wifes) 2024 Defender 110 p400e HSE (sold) 2015 Defender 110 Double cab 2004 Defender 90 Td5 |
21st Mar 2024 6:39pm |
Update.
Ok. So I can reveal that not all cars have the connectors in the doors for the Clear exit indicator. Mine doesn't.... Maybe I should have checked before buying the parts If anyone that has the connector is interested in them let me know. My car was built autumn 2023 110 p400e HSE with all options (well, obviously they skipped some...). My door Click image to enlarge Compared to one with connector. Should be to the right on the white bracket or around there. Wasn't hiding in the loom either on mine. Click image to enlarge 2025 Defender 130 V8 (DOA, new one coming) 2025 Defender 90 D250 (wifes) 2024 Defender 110 p400e HSE (sold) 2015 Defender 110 Double cab 2004 Defender 90 Td5 |
29th Mar 2024 11:28am |
