Home > General & Technical (L663) > New defender questions |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2749 |
For the rear door, open it to the position you want, then give it a little push back towards the vehicle immediately and it will lock in that position.
My Driver Assistance defaults to "medium" every time l use the vehicle. lt's only ever intervened twice in 10,000 miles. Both times at the same road junction when l have driven up to the centre line to turn right and it probably thinks l am going to have a head on with the cars coming the other way. However l would also be interested to know if it can be set with the GAP tool to remember the last setting, as with the stop/start function. Last edited by lightning on 17th Mar 2024 6:28pm. Edited 5 times in total |
17th Mar 2024 5:05pm |
Bobbobbobbob Member Since: 04 Jul 2023 Location: Brum Posts: 20 |
Thanks!
17th Mar 2024 5:07pm |
Mrburt Member Since: 04 Jan 2023 Location: Shropshire Posts: 30 |
Driver assistance offers a degree of customisation.
One long press on the steering wheel button will give you access to the customise section on the main display. Set your preferences for each assistance system. After every start up all you have to do is press the steering wheel button twice in quick succession and this will then hold your settings (customise) for the duration of the journey/ignition cycles. Hope this helps, once set up it really is no big deal every start up IMO. |
17th Mar 2024 8:21pm |
DrRob Member Since: 29 Mar 2017 Location: Hampshire Posts: 168 |
Which "steering wheel button" are you referring to Mrburt? MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie" Many Range Rovers and Land Rovers over the years π 1949 80" - still in family since 1975 |
18th Mar 2024 9:46am |
Yes I found that too thank you. It's the circle button next to the diamond. I would just really like not to have to do it every time.
18th Mar 2024 11:33am |
medallionno3 Member Since: 11 Mar 2023 Location: England Posts: 24 |
Itβs a legal requirement to have these features to default on now and is the same for all OEMs
18th Mar 2024 3:36pm |
Attached, hope this helps, Click image to enlarge |
18th Mar 2024 7:10pm |
18th Mar 2024 7:32pm |
