![]() | Home > Maintenance & Modifications > 75/90 in the diffs ? |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2463 ![]() ![]() ![]() |
75w-90 is fine in diffs. Puma 110" SW
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
The Castrol EPX is what should be used in the Defender diffs. The Syntrax Longlife is used in the Defender T-Box, but is also used in the D3/RRS diffs in place of the SAF-X0 that was originally specified.
It's all about additives now. ![]() |
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 ![]() |
So would I be mad to just put straight forward EP90 gear oil in Diffs and transfer box ?
It would not matter as long it is GL-5 (for diffs). GL-4 is good enough for the Tbox. Puma 110" SW
Just checked the can, It's Carlube EP90 API GL-5.
So I guess I'm alright with that. Just on the issue I find ATF gives smoother changes than MTF94 in my R380 box, doesn't seem to be any excess filings or anything at changes (do it every 12k miles), I presume it's not having an adverse effect on the box. |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
thanks all for the advice. I guess syntrax is OK then which is good as I have rather a lot of it in the shed !
