![]() | Home > For Sale & Wanted > [No longer Wanted] Max Raxx fixing plate |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2057 ![]() ![]() |
Nothing to do me, but complete lot on eBay….and open to offers. But you have to collect.
https://www.ebay.co.uk/itm/296264502978?_t...p_homepage |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2158 ![]() ![]() ![]() |
Mine came with the opposite hand bracket to the one shown in your photo, which I understand is the same as the one you have, but it didn’t cause me any issues in terms of fitting or use. Have you got an accessory at the rear that requires the opposite fitting?
Froogle-Yorkshireman Member Since: 10 Jul 2010 Location: Yorkshire Posts: 350 ![]() ![]() |
Thanks Daz110, I might need to go the full lot if I can’t find a plate on its own.
Interestingly Screbble, the reason I need a right handed bracket is because the upright has a kink to the left, which in theory means the carrier sits pretty much plumb centre when fitted to the right. However, if I use the left handed fitting it pushes the carrier too far to the left. Does that make sense? ![]() Click image to enlarge Proud owner 110 Utility XS Ex RR Sport HST V8 Ex Td5 90 |
Is that going on a Defender then?…..if so it doesn’t look as if it will clear the spare wheel if you have one fitted to the back door of your Defender.
No this is going onto the D4. Proud owner 110 Utility XS
Ah, ok.
Yes that does make sense! The dogleg on mine is outward to clear the spare wheel not left or right 👍 |
I seem to recall that MaxRaxx sell pretty much every spare part - might be worth a call?
Ah yes I realise the problem with my last comment now…
Sadly they went out of business a few years ago. Proud owner 110 Utility XS Ex RR Sport HST V8 Ex Td5 90 |
This is the left handed version that I need.
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1237 ![]() ![]() ![]() |
I might have one in the spares shed Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Brilliant - that would be great if you have.
![]() Ex RR Sport HST V8 Ex Td5 90 |
Still hunting if anyone should have one that they are looking to sell? Proud owner 110 Utility XS
