- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Ninja man
Hi Froogle,could you not cut the weld off with a cutting disc/grinder and turn it 180 and weld it the way you want it.im sure any fabricators locally may do it for you for a small charge,will be loads cheaper than buying the whole rack.ive got the same bracket going spare if you want it to try,you can have it but I’m down south
21st Mar 2024 6:12pm |
Froogle-Yorkshireman
Thanks Ninja Man, cut and weld might be the last resort
Exploring options. Proud owner 110 Utility XS
Ex RR Sport HST V8
Ex Td5 90
22nd Mar 2024 10:31pm |
