Home > Puma (Tdci) > Mt82 detent upgrade |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
https://www.defender2.net/forum/post696217.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
22nd Oct 2020 5:32pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 623 |
I have already sorted the jammed gear, but want to stop it doing it again.
I am going to try a new set of four Transit MT82 OEM detents as on inspection they can all be changed externally without opening the box up. They can’t be any worse than the twelve year old ones in it currentl. |
22nd Oct 2020 6:44pm |
I assumed that his last picture on that short instruction is showing the detent location.
This video from a forum member shows a nice way how to remove the detents @46:40 ?t=2801 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
22nd Oct 2020 7:06pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17388 |
All detents can be removed without stripping the box but I don't know if you can access them all with the box in the car. All MT82 detents are horrible cheap (but high priced) nasty things and I think only the springs differ between old and new.
I always make sure I lubricate the springs and balls thoroughly before fitting since I am not convinced they get any lube from the gearbox when in service. |
22nd Oct 2020 8:29pm |
Agreed - I am not paying £100 for four genuine detents! The OEM Transit ones are £9 each so will buy a set and try them.
Luckily my MT82 is early so has the easily removable ones. I have already previously replaced the shifter housing due to cracked lever ball end, had the shifter yoke come loose on the rail twice (not since I loctite studlocked it), fitted the revised shifter mounting collars and fitted the Ashcroft output kit. |
22nd Oct 2020 9:31pm |
Do you have part numbers for the Ford parts?
22nd Oct 2020 9:43pm |
https://www.cuscinettitop.com/ina/452833-f...49555.html
There is a good parts cross reference and part dimensions on the above page. OEM ones appear to be made by INA who are a decent Ford OEM. |
23rd Oct 2020 3:13am |
Those also appear to be the same style as the original type, so can be removed non-destructively. Let us know how you get on, this could be a very useful approach.
23rd Oct 2020 7:53am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8033 |
Had this problem with mine. Stuck in 2nd gear.
On removal of gearstick housing, detent was there but sticking up 8mm or so. Ball had come out the front along with the spring. Looks like it failed with ball coming out the front. It was the later modified detent too! Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
8th Mar 2024 4:53pm |
That's not at all good. Box out and strip job, or are the spring and ball recoverable?
8th Mar 2024 5:08pm |
Magnet and recoverable, thankfully Cheers
8th Mar 2024 10:08pm |
Phew!
9th Mar 2024 7:02am |
