Home > Puma (Tdci) > Mt82 detent upgrade
Oldowner
Mt82 detent upgrade
My MT82 jammed itself in first gear after my wife started it in gear and jolted the vehicle.
I have unjammed it however noticed that Land Rover issued an upgrade kit (LR017294) however cannot find any details on fitting. I am presuming the MT82 needs to be stripped to fit this detent kit, anyone actually done this mod?
Thanks
Post #863028 22nd Oct 2020 2:18pm
Dinnu
https://www.defender2.net/forum/post696217.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #863067 22nd Oct 2020 6:32pm
Oldowner
I have already sorted the jammed gear, but want to stop it doing it again.
I am going to try a new set of four Transit MT82 OEM detents as on inspection they can all be changed externally without opening the box up. They can’t be any worse than the twelve year old ones in it currentl.
Post #863083 22nd Oct 2020 7:44pm
Dinnu
I assumed that his last picture on that short instruction is showing the detent location.
This video from a forum member shows a nice way how to remove the detents @46:40
?t=2801 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #863090 22nd Oct 2020 8:06pm
All detents can be removed without stripping the box but I don't know if you can access them all with the box in the car. All MT82 detents are horrible cheap (but high priced) nasty things and I think only the springs differ between old and new.
I always make sure I lubricate the springs and balls thoroughly before fitting since I am not convinced they get any lube from the gearbox when in service.
Post #863102 22nd Oct 2020 9:29pm
Oldowner
Agreed - I am not paying £100 for four genuine detents! The OEM Transit ones are £9 each so will buy a set and try them.
Luckily my MT82 is early so has the easily removable ones.
I have already previously replaced the shifter housing due to cracked lever ball end, had the shifter yoke come loose on the rail twice (not since I loctite studlocked it), fitted the revised shifter mounting collars and fitted the Ashcroft output kit.
Post #863109 22nd Oct 2020 10:31pm
Do you have part numbers for the Ford parts?
Post #863111 22nd Oct 2020 10:43pm
Oldowner
https://www.cuscinettitop.com/ina/452833-f...49555.html
There is a good parts cross reference and part dimensions on the above page. OEM ones appear to be made by INA who are a decent Ford OEM.
Post #863127 23rd Oct 2020 4:13am
Those also appear to be the same style as the original type, so can be removed non-destructively. Let us know how you get on, this could be a very useful approach. Thumbs Up
Post #863158 23rd Oct 2020 8:53am
jst
Had this problem with mine. Stuck in 2nd gear.
On removal of gearstick housing, detent was there but sticking up 8mm or so. Ball had come out the front along with the spring. Looks like it failed with ball coming out the front.
It was the later modified detent too! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1027309 8th Mar 2024 5:53pm
That's not at all good. Box out and strip job, or are the spring and ball recoverable?
Post #1027311 8th Mar 2024 6:08pm
jst
Magnet and recoverable, thankfully Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1027340 8th Mar 2024 11:08pm
Phew! Thumbs Up
Post #1027357 9th Mar 2024 8:02am
