Home > Maintenance & Modifications > Painting a 110 |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 627 |
I was happy with the work Ark Tech Autos in High Wycombe did on mine. 1995 Defender 110 CSW
1971 SIIA Lightweight |
5th Mar 2024 7:07pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 |
I’m 10 mins from there. What did it cost you if I can ask please?
Appreciate the reply 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
5th Mar 2024 7:15pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2048 |
CSK automotive specialise in our 316 defenders and have a paint shop, about 60 miles from you but worth a call.
https://www.cskautomotive.co.uk/the-land-r...hop-valet/ |
5th Mar 2024 7:40pm |
Thanks, have used Chris for much in the past. Didn’t know he paints them too. 1951 80" S1 2.0
5th Mar 2024 8:58pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20468 |
I’d definitely go for Chris if you are within range, sadly a long way from me though.
Most of the work is, prep and masking, and the prep, methodical cleanliness and correct grade products. But for the best jobs, you really could do with the right environment and that is a paint booth as the humidity levels needs to be less than 60% max, plus correct temp and ventilation etc. I think about 21 to 24.C, at around 45 to 50% humidity or less is ideal, contaminants are the enemy as is moisture. As far as I’m aware professional paint probably for a 110 is roughly £3300, approximately a bit less for some such as a 90 for a collage repaint. Roof repaint for an example I’ve heard of Approx £600 too £800, as that a lot more simple to prepare and paint. It’s not really the paint that is expensive, it’s the cost of the booth for energy I.e. heating and the labour, there is a lot of labour. Don’t quote me exactly on the prices, they are roughly what I’ve heard of and depends on where in the country. You’d want a nice professionally done job otherwise you may as well DIY if not, the trouble is with the latter is you’d need perfect summer conditions and keeping contaminants at bay and having somewhere to do it also is a job in its self. For such a big job as a compete repaint then a full in-booth professional job is the best way to go. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
5th Mar 2024 9:09pm |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 |
Phil Waller at Sarratt - has been painting new cars for me since 2005ish. Tell him I sent you https://www.classicdreamworks.co.uk/ 07983530756 |
5th Mar 2024 9:36pm |
Thanks Jeremy
Have emailed him 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
6th Mar 2024 8:42pm |
