![]() | Home > In Car Electronics > Wiring loom into door |
Wag Member Since: 27 Nov 2023 Location: Londonderry Posts: 21 ![]() ![]() ![]() |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
Thanks Wag that was the answer I was hoping for.
Do you know if I can pull the plugs through the grommet hole to disconnect or do I have to access from inside the footwell? |
You'll be able to gently work them free through the grommet hole. The plugs are to big to fit up the rubber flexi,so it will be a cutting and soldering game behind the door card if anything is brittle and nips but you are replacing the door so it shouldn't matter .
Thanks very much - super helpful 👍
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20652 ![]() ![]() |
Connectors are just into the bulkhead below the A pillar if I remember rightly, or you can disconnect in the door there shouldn’t be any need to cut anything just work the rubber out of its seats on each side if you need to move it. TheThunder Rolls🇬🇧🇺🇸
⛽️🛢️⚙️🧰💪 Last edited by custom90 on 4th Mar 2024 10:19pm. Edited 1 time in total |
Thanks Steve
