Home > In Car Electronics > Air con wiring |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17202 |
I'm pretty sure it is not the inner wing loom.
3rd Mar 2024 11:56am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2177 |
There should be a brown connector behind the fuse panel cover which plugs into the under dash unit.
Mo Should have read the original post properly, doh ! The Land Rover 90 - Many are called, few are chosen. Last edited by Mo Murphy on 3rd Mar 2024 8:28pm. Edited 1 time in total |
3rd Mar 2024 2:51pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 496 |
The connector isn't an Econoseal.
It's a 2-way variant of the BMW connector series used on the fuel pump/sender. The connector can be purchased from Land Rover, sold without terminals or seals, as YPC110300 https://britcar.com/product.php/422951/549..._to_follow It can also bought from BMW, as a universal keyed connector in 'Water Blue', as Part No. - 61 13 8 352 390 Click image to enlarge However, 61 13 8 352 390 is around twice the price of YPC110300 from Land Rover Terminals and seals are not available from Land Rover, except as really expensive pre-crimped 'repair wires' Terminals and Seals from BMW, are - Female terminal, 0.5 – 1.5mm² – 61 13 1 376 202 Wire Seal, 0.5 – 1.0mm² – 61 13 1 383 789 Female terminal, 1.0 – 2.5mm² – 61 13 1 376 204 Wire Seal, 1.0 – 2.5mm² – 61 13 1 383 791 Female terminal, 2.5 – 4.0mm² – 61 13 1 376 206 Wire Seal, 4.0mm² – 61 13 8 352 924 . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
3rd Mar 2024 2:55pm |
PoormansXS Member Since: 21 Oct 2023 Location: Lincolnshire Posts: 48 |
Are you fitting an aftermarket kit with loom? I have some info on this as I’ll be tackling mine soon. If of interest I’ll post what I’ve got.
3rd Mar 2024 5:02pm |
smurf500 Member Since: 08 May 2015 Location: oxfordshire Posts: 53 |
Sorry I’ve only just noticed this,yes please,no I’ve bought a second hand kit off of eBay,my td5 90 doesn’t have the connectors for the compressor or fan.
16th Apr 2024 9:22am |
Thanks paulmc and mo
16th Apr 2024 9:23am |
