Home > In Car Electronics > Air con wiring
smurf500
England 2005 Defender 90 Td5 HT Belize Green
Air con wiring
I’m retrofitting air con to my td5 defender.is the air con electric fan wiring run off the engine loom or does it come from the inner wing loom?by any chance does anybody have the part no for the econseal plug that will connect to the fan.thanks
Post #1026657 3rd Mar 2024 10:43am
I'm pretty sure it is not the inner wing loom.
Post #1026660 3rd Mar 2024 10:56am
Mo Murphy
There should be a brown connector behind the fuse panel cover which plugs into the under dash unit.
Mo
Should have read the original post properly, doh ! The Land Rover 90 - Many are called, few are chosen.
50 Shades of Pennine Grey
Post #1026678 3rd Mar 2024 1:51pm
PaulMc
The connector isn't an Econoseal.
It's a 2-way variant of the BMW connector series used on the fuel pump/sender.
The connector can be purchased from Land Rover, sold without terminals or seals, as YPC110300
https://britcar.com/product.php/422951/549..._to_follow
It can also bought from BMW, as a universal keyed connector in 'Water Blue', as Part No. - 61 13 8 352 390
However, 61 13 8 352 390 is around twice the price of YPC110300 from Land Rover
Terminals and seals are not available from Land Rover, except as really expensive pre-crimped 'repair wires'
Terminals and Seals from BMW, are -
Female terminal, 0.5 – 1.5mm² – 61 13 1 376 202
Wire Seal, 0.5 – 1.0mm² – 61 13 1 383 789
Female terminal, 1.0 – 2.5mm² – 61 13 1 376 204
Wire Seal, 1.0 – 2.5mm² – 61 13 1 383 791
Female terminal, 2.5 – 4.0mm² – 61 13 1 376 206
Wire Seal, 4.0mm² – 61 13 8 352 924
. Paul.
Post #1026680 3rd Mar 2024 1:55pm
PoormansXS
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
Are you fitting an aftermarket kit with loom? I have some info on this as I’ll be tackling mine soon. If of interest I’ll post what I’ve got.
Post #1026700 3rd Mar 2024 4:02pm
smurf500
Air con
Sorry I’ve only just noticed this,yes please,no I’ve bought a second hand kit off of eBay,my td5 90 doesn’t have the connectors for the compressor or fan.
Post #1031739 16th Apr 2024 8:22am
smurf500
Thanks paulmc and mo
Post #1031740 16th Apr 2024 8:23am
