Home > Puma (Tdci) > LOF MT82 Upgraded Adapter Shaft
Page 2 of 2 <12
The rear face of the gearbox, the front and rear faces of the adaptor housing, and the front face of the transfer box are all machine and should be perpendicular to the axis of the shafts. I haven't ever seen a suggestion that there is a problem with this.
The position of the adaptor housing on the back of the gearbox and the transfer box on the back of the adaptor housing is defined by locating dowels and there should be no problem with this, provided of course that the casings are all machined to an acceptable tolerance. Machining to an acceptable tolerance should be no problem at all in modern process, but there are ways in which this could go wrong and it is almost impossible to check without very sophisticated equipment. Landrover's proven track record in screwing up simple things that other manufacturers by-and-large stopped screwing up decades ago and the general shoddy implementation of the TDCi installation means that it is not outwith the realm of possibility that there is a problem here.
Given that the MT82 and the LT230 have both been around in other applications for years without problems it would seem likely that if there is an issue it is with the adaptor housing, the new bespoke part.
Any positional error or this type would result in the splined coupling driving at an angle (like a propshaft UJ) and will cause rapid wear, and will also probably tend to drive the joint apart, which is another often-seen failure mode. It is one theory which fits all the symptoms and evidence but it is unproven so is just a theory.
There must be some factor at work which causes the huge variability in life expectancy of the standard coupling. Lubrication is clearly a factor but not the only factor, since the variability existed when none were lubricated and still existed after there were lubricated on assembly. It is possible that there are manufacturing or material variations in the parts themselves, but again this is very difficult for anyone other than the manufacturer to determine, and the fact that certain vehicles have got through a succession of couplings suggests the problem is on the vehicle not the couplings, again pointing to the housing.
Something is clearly amiss. The design concept is sound and by any calculation the dimensions of the splines is entirely sufficient for the transmitted power, so it should be fine. There are many Defenders on which it is fine, which have never failed, yet by 2008 there were many failures being reported.
Post #854895 8th Sep 2020 8:05am
Bluest
I tend to agree with Blackwolf, there is some unknown variable in the way these things have been manufactured and assembled. It would be interesting to pull a complete assembled gearbox/transfer box whole that has failed and see if the mounting face of the bell housing is perfectly parallel with the transfer case output flanges. If not that would at least confirm something was out of alignment in between. 2007 110 TDCi Station Wagon XS
Post #854902 8th Sep 2020 8:41am
DSC-off
Grenadier wrote:
Please accept that my knowledge of these things, and these specific parts, is limited. But if the MT-82 mounting surface and the transmission box mounting surface are true, are unadulterated, are as per made in their respective factories, and if no shim or spacer has been added during fitting, how can the gearbox and transmission box be out of alignment? One assumes (here’s my gap in knowledge) that both will have been made with flat faces, 90 degrees to their overall shape/design, for flush fitting? If this is the case, where/how does the misalignment come from? I understand that Defender parts (indeed LR parts) may not be made with the tolerances demanded by NASA.
The miss alignment probably comes from an accumulation of tolerances, this might help to illustrate.
Angles and offsets exaggerated to show possible effects,
https://www.defender2.net/forum/topic62521-135.html
Post #854943 8th Sep 2020 11:30am
Dinnu
My 2012 90 has a history of eating through adapter shafts. I think 4 in all in just over 110kmiles.
Recently needed to take the transfer box out because of an oil leak (Ashcroft adapter shaft aluminium cover was badly fitted and leaked there).
Knowing the history, I tried to see what could be the cause. With the limited tooling I have, I checked the planarity of the adapter housing faces, and they were within 0.10mm (100 microns or less than 4 thousands of an inch). All dowel pins had a good fit. I could not get relative position measurements between dowel holes on one side to the other side of the adapter plate.
What I also noted, the Ashcroft adapter shaft had absolutely no wear in the usual splines. Unfortunately, however, mine suffered some wear on the gearbox mainshaft (https://www.defender2.net/forum/topic59735-240.html).
Possibly the 'flow' of oil from the main gearbox to the kerb side helped to preserve the usual adapter splines Laughing 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #854989 8th Sep 2020 3:37pm
Grenadier
Excellent, thanks DSC Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #855148 9th Sep 2020 10:35am
Devon-Rover
LOF shaft fitted yesterday.
Really straightforward install get it all in and that's one problem area dealt with.
and i did the clutch whilst i was in there too
 Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #859720 4th Oct 2020 10:46am
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
I'd even go one step beyond : LR planned the 2 splines because there really exist fab tolerances. Otherwise it could have been just 1 single part + 1 spline (like LOF suggest it to be).
You can find this sort of splines in almost any agricultural vehicle and tolerances are even worse.
And any technician can explain what would happen if these splines moved without lubrication ...
Post #860384 7th Oct 2020 9:17pm
Dinnu
Perhaps LOF want to mitigate the LT77 and R380 where the mainshaft is one piece going into the transfer box. But for both LT77 and R380, the transfer box bolts on directly to the gearbox without adaptor housings. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #860414 8th Oct 2020 7:42am
pedrocandrade
Brazil 2011 Defender 110 Puma 2.4 SW Epsom Green
Hello everyone. I'm just wondering if we have news on the durability of LOF's solution here. I'm thinking of buying one for my 2011 Puma as it will soon get a new clutch from LOF as well.
Thanks!
Post #1026539 1st Mar 2024 11:27pm
Devon-Rover
25 odd thousand miles later and AFAICT it is just as sound as the day it went in. Thumbs Up Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #1026589 2nd Mar 2024 3:54pm
nidge n
only 12K miles on mine, but shaft and clutch have been great Thumbs Up
Post #1026606 2nd Mar 2024 7:36pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
I too had the LOF shaft fitted last year, my local LR specialist says a much better upgrade than OE Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #1026607 2nd Mar 2024 8:06pm
Page 2 of 2 <12
