Home > Puma (Tdci) > Puma lights left on warning bing? |
ScarboroughSeadog Member Since: 21 Jul 2022 Location: Scarborough Posts: 110 |
My 2013 plate DCPU 2.2 Puma does nothing if I take the key out and leave the headlights on accidentally (except drain the battery!)
My pals 2016 plate Puma panel van pings a warning if he does the same- just noticed this weekend. Have I got a faulty binger? If so, what needs replacing/ adding to give me the same reminder? Thanks |
26th Feb 2024 12:24pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
2015 model year onwards have the lights on pinger 1988 90 Td5 NAS soft top
2015 D90 XS SW |
26th Feb 2024 12:34pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17450 |
The standard wiring on my 2007 vehicle has a relay which means that the headlights are only on if the ignition is on, so it is not possible to leave them on when you leave the vehicle. It is possible to leave the sidelights on. |
26th Feb 2024 1:15pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2038 |
3 wires and one of these https://www.carbuilder.com/uk/lights-left-on-warning-buzzer
Details from the carbuilder description. LIGHTS LEFT ON WARNING BUZZER This little buzzer will end the pain of a flat battery after leaving the lights on. Here's how it works: When your lights are on they feed 12v + to terminal 2. When your door is open, the door switch makes an earth connection to terminal 3. If your ignition switch is on, the buzzer is silent but when you turn your ignition switch off and the door is open the buzzer activates. Three 1/4" male spade terminals. Wiring: Terminal 1 - 12v+ from ignition switch Terminal 2 - 12v+ from side lights Terminal 3 - through door courtesy switches to earth. |
26th Feb 2024 1:24pm |
Great stuff- thanks for the link to the buzzer.
27th Feb 2024 3:03pm |
JPE Member Since: 19 Nov 2018 Location: South West England Posts: 335 |
Every time I get out of mine I walk round the front to see if the lights are on.
It's just a habit now, I've done it for years. Drives my wife mad as I only do this after first faffing with the various security things! |
27th Feb 2024 6:21pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3425 |
I find the lights switch close enough to the ignition that automatically ‘feel’ that the lights are still on. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
27th Feb 2024 6:47pm |
peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 293 |
I agree - it’s actually slightly difficult removing the key from the ignition switch with the headlight switch on main beam. I think it’s another Land Rover “aide memoire” which was purposefully in built at the design time. They could have installed a bong or buzzer warning aid, but what would be the fun in that? Manual override much better and more reliable.
27th Feb 2024 7:11pm |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 361 |
I find it mega relaxing that the car makes so little pings, ringing etc.
I could even do without the fuel-reserve ping as long as it is illuminated! |
1st Mar 2024 2:00pm |
trevorg Member Since: 28 May 2022 Location: Aisne Posts: 51 |
So the fuel-reserve pings? Didn’t know that!
1st Mar 2024 3:57pm |
Mine gives one "bong" when the light comes on. That, as far as I know, is the only intentional electronic noise a 2007 2.4 Defender makes, and it is quite enough. That one is useful.
1st Mar 2024 4:23pm |
My old 90 was even better, as the low fuel warning light used to start flashing before it gets low enough and illuminates all the time. Probably not intentional , but very effective. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
2nd Mar 2024 6:21am |
