- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
34064
![](templates/vbnew/images/spacer.gif)
Pulling the plug on the MAF gives the ECU a standard measurement of air flow where as the MAF adjusts it i have run around for years without one doing no damage but with one you get a better drive and fuel economy not that you bought a defender for those things 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
1st Mar 2024 3:27pm |
landy andy
N5tys wrote:hi hope all is well
i have not had my defender td5 long and im just working my way through it sorting various issues !
the truck seamed sluggish pulling away until i disconnected the MAF sensor though is this doing any damage to the engine ?would anyone recommend replacing the sensor ? the truck was re mapped before i purchased it i believe a stage 1 ? with an EGR delete im also not sure if this is causing any damage to the truck ? i was potentially looking to take her back to standard as i did not really buy the truck to drive fast !
any help would be appreciated
Leave the MAP and EGR delete in place as they drive much better with them. I would and have fitted a new MAF sensor. Again drivers better, uses less fuel, smoother drive. Just fit a quality part not a cheapy
1st Mar 2024 4:49pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
