Home > Faults & Fixes (L663) > Water noise
c4skp
Water noise
A noise of water moving around when turning has been driving me mad, thought it was the fuel tank, them maybe under the boot floor.
But have found it Wink
The back door had a couple of litres inside.
Post #905398 27th May 2021 10:01pm
c4skp
I had to remove a rubber grommet from the underside to drain it
Post #905399 27th May 2021 10:02pm
Simon Audi
You need to find out where its getting in - because I am sure long term that wont be good...
back to the dealer..
Post #905414 28th May 2021 5:07am
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
There’s a known SSM for water ingress mine is getting something done next time it goes in but they didn’t say where it was.
Post #905464 28th May 2021 10:53am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Water ingress is in the DNA of all Defenders.....
Post #905489 28th May 2021 2:44pm
Digger2000
Mines going in on the 16th for various faults/fixes will update on the water ingress then.
Post #905502 28th May 2021 3:44pm
c4skp
Will book it in and also see if they can sort out the SIM card not always working for online services 🤞
Post #905554 28th May 2021 8:35pm
Archon
Resurrecting an old post... was this ever sorted? After hearing sloshing i took the grommet out and gallons poured out
It's going in tomorrow by chance anyway and still by a whisker in warranty
Any help gratefully received
First post so please be gentle
thanks
Post #1025991 26th Feb 2024 10:13am
spudfan
Ireland
Might be beneficial to leave the drain grommet out until the issue is sorted. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1026036 26th Feb 2024 4:19pm
Archon
Yes, thanks, done that. Problem is grommet isnt at lowest point so there’s still a reservoir behind Rolling Eyes
Post #1026040 26th Feb 2024 4:26pm
spudfan
Ireland
Probably seems like heresy saying this, but would it be feasible to drill a hole at the lowest point to stop water building up? Just make the diameter the same as the existing whole and you can plug it with a grommet when the issue is solved. If you do drill a new hole do not for get to put some paint on the new edges to stop it rusting. 1982 88" 2.25 diesel
Post #1026042 26th Feb 2024 4:35pm
