![]() | Home > Td5 > SHOCKing ideas FOX or Terrafirma? |
LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 343 ![]() ![]() ![]() |
that will be brilliant - Have you got list of kit/ changes to make for your prep? 4.0 V8 Defender 90
My Instagram |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 848 ![]() ![]() |
Cool, not familiar with that event. Looks like it is motorbikes are you just following the route or in support? For that kind of use, yes remote res shocks sound sensible. Do you not find 35's rub under articulation if you need the lift to fit them? As when a live axle suspension compresses it takes away all the lift. I see you said you are fitting front dislocation cones, obviously they are cheap and easy to fit, so why not. Although unless you are running a short stiff spring or have done something else to increase travel, very few LRs can dislocate the front springs. Even the promo/poser shots of the Gwyn Lewis Comp truck it isn't dislocating the front suspension. |
Biscuits Member Since: 27 Mar 2023 Location: Kent Posts: 69 ![]() ![]() ![]() |
Originally a motorbike event, but opened up to select "old" 4x4's too now...
Have only had the 35's rub once on full articulation, was the stupidly long rear seat bolts ![]() 2001 90 TD5 Soft Top - Epsom Green 2024 90 D300 HSE X-Dyn HT - Santorini Black |
No worries, sounds like a cool event. Hope you post some info/photos of it.
