Home > Puma (Tdci) > ABS Problem
mrfirepro
United Kingdom 1996 Defender 90 300 Tdi HT Bonatti Grey
ABS Problem
I recently overhauled the complete braking system on my 2007 2.4 Tdci, whilst there I replaced all the bearings.
I'm now getting the following fault on my ABS system
16-07 Front Left sensor output too low - Intermittent - happened 16 times
I've changed the sensor and still have the fault, before I go any further are there any suggestions of anything I could have done wrong with the bearing to cause this fault as it was fine before I replaced the brakes and bearing.
Any help much appreciated
Post #1025573 22nd Feb 2024 10:56am
geobloke
It sounds like there isn't enough voltage being registered by the ECU coming back from the sensor. So first step would be check and clean the earths.
Next step would be to check the loom and connections for corrosion.
After that I would check the voltage output of the opposite wheel sensor and see how much lower the bad one is.
Let us know how you get on. Interesting problem, not seen this one before.
Post #1025576 22nd Feb 2024 11:13am
Another possibility is that the senor is not close enough to the reluctor ring, which would result in the inducted voltage in the sensor being lower than normal. It may be as simple as giving the sensor a gentle tap into the swivel pin.
Post #1025583 22nd Feb 2024 11:29am
geobloke
Good call Blackwolf Thumbs Up
Post #1025584 22nd Feb 2024 11:30am
Screbble
I had that issue and as described a gentle tap (be careful) resolved it.
The sensors themselves are relatively inexpensive and plug and play - albeit you will need to throughly clean the surrounding areas and locating hole.
Post #1025825 24th Feb 2024 2:07pm
