![]() | Home > Technical > Td5Rev Counter (Again) |
MOD_John Member Since: 21 Feb 2024 Location: Lincolnshire Posts: 2 ![]() ![]() |
No worries, I finally found it...
Here's the link for anyone else in the same situation: https://www.defender2.net/forum/topic65167.html |
Zimblewinder Member Since: 12 Jan 2019 Location: Geelong Posts: 46 ![]() ![]() ![]() |
added bonus from taking it from the stator pin over the ecu pin is that the tacho will drop out if fuse #5 pops loosing your alternator charge. You can replace the fuse before the battery is driven flat, or if you're already out of luck, the tacho dropped out will help you quickly identify this charging problem.
