Home > In Car Electronics > Roof console switch pod
Vitesse
Hi. not sure if this has been looked at before, but does anyone know of a switch pod (to take the standard Defender switches) that mounts where the interior light sits. Possibly incorporating the interior light into the design? Ideally say 6 switches. I am aware of a design that has the facility to hold a DIN size radio etc, but I need just the ability to fit standard defender switches. Thanks in advance.... Thumbs Up 2015 90 XS Santorini Black
Post #1025340 20th Feb 2024 5:59pm
I don't believe that there is an COTS solution but there is not reason you couldn't fit a custom panel into the MUD roof console. It would be quite straightforward especially if you knew someone who could 3D print the panel for you.
Most folk use other makes of switch up there because genuine LR ones are not great in most respects.
Post #1025359 20th Feb 2024 7:45pm
geobloke
A combination of the RDX roof light switch pod and the MUDSTUFF TD5/TDCI switch panels might work
https://www.ebay.co.uk/itm/235031495145?va...s0QAvD_BwE
https://www.mudstuff.co.uk/collections/mud_defender_switches
RDX also do the switch pod for Carling style switches so loads of options there.
Post #1025376 20th Feb 2024 9:30pm
Puddings 3112
I was running the Mud roof console with the cabin light and the single din 6 carling switch panel. It was a nice tidy compact solution. I know they are not LR OE switches but they do have a nice positive feel to them.
Swapped it out for a CB as the switch count was overkill for my needs where as fulfilling my childhood Smokey and the Bandits fantasies was far more important!
Post #1025390 20th Feb 2024 11:30pm
Vitesse
Thanks all. Yes it looks like a bespoke option is likely here as I want to definitely use the standard LR switches but in a more sleek design console. I will give it some thought. Maybe consider a 3D printed special …. Bow down 2015 90 XS Santorini Black
Post #1025405 21st Feb 2024 8:01am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
I went to CARLING switches in MUD roof console.
Just be carefull with 3D printing - it could be quite hot there in summer, so use the right filament material. I have seen colapsed 3D printed holders, left behing front screen in summer. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1025580 22nd Feb 2024 11:25am
