![]() | Home > In Car Electronics > Roof console switch pod |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
I don't believe that there is an COTS solution but there is not reason you couldn't fit a custom panel into the MUD roof console. It would be quite straightforward especially if you knew someone who could 3D print the panel for you.
Most folk use other makes of switch up there because genuine LR ones are not great in most respects. |
A combination of the RDX roof light switch pod and the MUDSTUFF TD5/TDCI switch panels might work
https://www.ebay.co.uk/itm/235031495145?va...s0QAvD_BwE https://www.mudstuff.co.uk/collections/mud_defender_switches RDX also do the switch pod for Carling style switches so loads of options there. |
Puddings 3112 Member Since: 05 Dec 2020 Location: Down South Posts: 49 ![]() |
I was running the Mud roof console with the cabin light and the single din 6 carling switch panel. It was a nice tidy compact solution. I know they are not LR OE switches but they do have a nice positive feel to them.
Swapped it out for a CB as the switch count was overkill for my needs where as fulfilling my childhood Smokey and the Bandits fantasies was far more important! |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 389 ![]() ![]() ![]() |
Thanks all. Yes it looks like a bespoke option is likely here as I want to definitely use the standard LR switches but in a more sleek design console. I will give it some thought. Maybe consider a 3D printed special ….
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 639 ![]() ![]() ![]() |
I went to CARLING switches in MUD roof console.
Just be carefull with 3D printing - it could be quite hot there in summer, so use the right filament material. I have seen colapsed 3D printed holders, left behing front screen in summer. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
