Home > Maintenance & Modifications > How to determine if Defender needs new gearbox mounts
Mogboy
Australia 2007 Defender 110 Puma 2.4 SW Belize Green
My 2007 Puma Defender 110 has 377,000kms and still has the original gearbox mounts. They are intact, but while doing a routine check, I'm wondering if they are a bit soft now.
Pushing on the transmission from below, I can move it up about 4mm. At rest the rubber part of the mounts distorts with the downward weight, so that the side profile changes from a rectangle to a rhomboid shape. I'm not noticing any problems, just looking at preventative maintenance, and if this is still "in spec"?
Cheers for any input.
Post #1025133 19th Feb 2024 2:44am
Excess movement is a sign of play, if in doubt swap them, they are relatively cheap really. TheThunderRolls🇬🇧🇺🇸
Post #1025171 19th Feb 2024 1:43pm
Mogboy
Yes for sure Steve. Cheers for that! Being the originals and done those kms, it's not a biggie. More a point of curiosity on my part, I guess.
Post #1025249 19th Feb 2024 10:47pm
I’d imagine LR would suggest they are good for at least 80k miles, at a guess so I’d imagine yours are well over that.
Corregations help wear them.
You don’t hear so much about engine mounts, not many people have any issues with that.
Seems like they last extremely well!
I had the gearbox mounts changed on mine about 60k, I don’t think there was much point but they did have a little play in them I’d say a small amount is normal. TheThunderRolls🇬🇧🇺🇸
Post #1025258 20th Feb 2024 12:08am
Dinnu
Rubber generally tend to harden with time, develop cracks (rot), and can delaminate from the metal backing.
My mounts, at almost 12 years are still soft, show no rot, and still intact, albeit they are also skewed in shape. I do not worry about them.
Note that there is a higher risk that the chassis around the mounting bracket that cracks than the mounting itself failing. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1025262 20th Feb 2024 5:53am
