Home > Puma (Tdci) > DIY drawing hammer with adapter for the 2,4l puma injectors
khamuul
Germany 2007 Defender 110 Puma 2.4 SW Tonga Green
I wanted to build a drawing hammer for the puma injectors. I thought about the adapter for a while and this is the result:
Drill the appropiate diameter hole in a piece of flat steel with the step drill.
Cut the steel into two pieces it will fit right onto the injectors head.
Take a piece of square steel and drill the needed holes. Put it over the injector and install the two steel pieces.
On top of the square steel the drawing hammer can be mounted and will be right in line with the injector.
This adapter did a good job on my puma. Thumbs Up
Post #1025048 17th Feb 2024 10:55pm
