![]() | Home > Technical > Running lights not working after LED upgrade |
Newbie Member Since: 04 Oct 2023 Location: Maryland Posts: 14 ![]() ![]() |
Alright, lads, here is my update... though it isn't a good one. I've actually gone from annoyed to quite angry.
I mentioned in passing that in addition to my running light issue I also noticed bleed-through with my signals. So, for example, if the right signals were engaged it would flash brightly, but the left signals would blink faintly as well. This same thing was happening with the indicator on the dash. To be sure, it was doing this the last time I drove it. I started it up today and everything was working fine. ?!?! All of my signals were working as they should. (Still no driving lights of course.) I couldn't leave well enough alone, though, because if it acted up before, it would surely act up again. So I installed the recently-acquired RDX flasher relay from B.O.B. that everyone seems to rave about and now, not only did my signals not work, I watched my fuel gauge and voltmeter drop to zero! WTH? As a reminder, the relay that came with my LED lights was three-pin. The original flasher was four-pin and the RDX is four-pin. I believe it should be four-pin and I think I was just "lucky" that worked as well as it did (even though not perfectly). I removed the RDX relay and re-installed the three-pin one. Nothing. Switched back... nothing. After cursing up a storm I reinstalled the three-pin relay one last time and turned the key to the ACC position. The fuel gauge rose; the voltmeter rose and the signals came back and came back well. I was back to where I started the day and the three-pin relay was installed. So whatever the hell happened there, I thought I was back on the good foot. I turned the truck off. Then I did what I believe you suggested earlier, blackwolf, and removed both of my tail lights to see if the front running lights (side lights) would work. They didn't, of course. So I reinstalled the tail lights completely tired of working in the cold and started up the truck. No lights; no fuel gauge; no voltmeter. My headlights work and my hazards work. I think that's it. And they had just worked ten minutes earlier! So I actually started my day with the truck in a better state than it was left last week - signals working as they should - and finished my day much, much worse than I have been at any point in this process. I've gone from not being able to drive at night to not being able to drive at all. I think you can tell I can only follow so much of the technical jargon. And I get that in the grand scheme things this is a relatively minor issue; certainly not mechanical (knock wood). I have been receiving very helpful advice on this board, even if I don't understand all of it. The way things are going, I'll likely print all of this up for my mechanic and have him suss it out. It shouldn't HAVE to involve a mechanic though. I'm changing out lights for goodness sake. I liken this to changing out mudflaps and then having my brakes fail. I don't want you all to keep wasting your time with my issue. If something about this newly evolved problem that now impacts my gauges (!!!) speaks to you and you think there is something you can pass on to me (Newbie by name; Newbie by nature) that I may follow and be able to implement, I'd be very grateful. Until then, who knows... I may start it up tomorrow and find that even my running lights are working. (Even though we all know they won't.) Thanks, guys. Frustratedly yours, Jim |
