![]() | Home > Technical > Tailgate electrics |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 323 ![]() ![]() ![]() |
Highly likely to be an earth issue, the rear door loom has a couple of multi plugs behind the drivers side tail light. If you’ve got 12 volts at the vehicle side of the plug when the heated rear window /brake lights/rear wiper are switched on check for corrosion in the earth circuit. Earths wires are pretty much always black.
