Home > Technical > Tailgate electrics
smithpadstow
Tailgate electrics
Rear wiper, demister and centre high mount brake light do not work.
Fuses ok - a visual inspection behind the door card looks to be ok.
Am I right in thinking it is most likely an issue with the loom to the rear tailgate?
Any advice most appreciated. Is this a common issue etc.?
Post #1024725 14th Feb 2024 6:14pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Highly likely to be an earth issue, the rear door loom has a couple of multi plugs behind the drivers side tail light. If you’ve got 12 volts at the vehicle side of the plug when the heated rear window /brake lights/rear wiper are switched on check for corrosion in the earth circuit. Earths wires are pretty much always black.
Post #1024726 14th Feb 2024 6:34pm
