Home > Faults & Fixes (L663) > Trunk door doesn't open properly |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 284 |
That’s an interesting question, because mine has a similar issue. My car had its PPF applied before I picked it up so I don’t know what the lock operation was like before the PPF was applied. I have assumed until now that the slightly erratic operation was because I wasn’t standing close enough to the rear of the car when pressing the latch button. I’ll see if I can test the door operation on another Defender when I get the chance. I’ll also talk to my detailer at some point
The Carpathian Edition has PPF installed from the factory so that tends to rule out the film causing the issue I guess. My door does open so it’s not an urgent question for me at the moment. |
13th Feb 2024 10:04pm |
kulvershtukas Member Since: 13 Feb 2024 Location: Tallinn Posts: 2 |
Went to the dealer today, they checked everything and told its because of the PPF (film). The door rubber sits so tide to the body of the car that when it goes against the PPF edge, the lock feels the resistance and blocks the opening (the perimeter of the contact of the edge and rubber is so big that resistance is huge). So I went to the PPF installer straight away and they cut the PPF (made it shorter), so the door rubber is not in contact with PPF any more. And everything started to work as should. So problem solved.
14th Feb 2024 10:05am |
Great! Thanks for the update
15th Feb 2024 7:53pm |
