Home > Tdi > Replacement fuel solenoid wire |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 791 |
Not sure what you mean by 'locking clip'?
It's just a female shielded spade connector. If it's falling off then tighten up the connector with pliers or get a better connector. |
10th Feb 2024 11:48am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6568 |
Yes, I have them, and I can supply as a kit of parts or with wire attached.
But I imagine the cost to post to Aus massively outweighs the cost of the actual connector 1988 90 Td5 NAS soft top 2015 D90 XS SW |
10th Feb 2024 12:42pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 496 |
The fuel cut-off terminal (C0198), is a TE/AMP 6.3mm 'Posi-Lock' terminal with a Black cover (AAU1010)
Click image to enlarge They're used in multiple locations on a Defender. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
10th Feb 2024 10:41pm |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1840 |
Thanks very much for posting that picture! Every day’s a school day.
I didn’t know such thing existed, and as ‘OldSkool’ has said above I’ve just used normal insulated spade terminals here. Survived for about 10 years or so since the last time I replaced one so clearly not a massive issue, but now that I know about the “proper” thing I’ll get some ordered. Ta Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
11th Feb 2024 12:48pm |
PAT303 Member Since: 25 Feb 2013 Location: Australia Posts: 125 |
Don't work out here mate, the constant vibration from corrigations loosens them to the point they fall off, I've squished them with pliers and within weeks they are loose. |
12th Feb 2024 12:30am |
Paul, thanks mate, exactly what I was after, cheers.
12th Feb 2024 12:31am |
