Home > Puma (Tdci) > Defender Puma TDCI 2008 Handbrake
Page 2 of 2 <12
Drum on mine, never had an issue in 14 years. I kind of feel that it’s one of those, it doesn’t break, don’t fix it.
Why does the disc handbrake rattle is it the shoes on the brake not backing out enough? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1023450 3rd Feb 2024 2:49pm
andy63
It's the pads I believe.. Especially the so called fixed one.. They are both just loose fitted into the calliper held in place as supplied by a bit mastic.. So they eventually do rattle.. There are fixes I've seen on the tube if it annoys you.. If you hear the rattle you do know the calliper has backed off and isn't exerting any pressure on the pads👍😅..
I have on occasion heard it and just lifted the hb lever a fraction and it disappears😂
Post #1023458 3rd Feb 2024 3:44pm
mwestcrew
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Baltic Blue
I believe the X Eng disc system was developed for off roaders to deal with the problem of the drum getting full of mud and water.
My view is that if you rarely immerse the drum in water or mud it’s a perfectly good system that requires little or no maintenance. If the shoes are properly adjusted they will never wear out, and only very occasional adjustment will be needed, probably due to components stretching. 2011 130 Utility Body
2005 110 Van
Post #1023760 6th Feb 2024 11:23am
Page 2 of 2 <12
