![]() | Home > Group Buys > Stainless Steel Tub Cappings (90 with no bulkhead) |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3525 ![]() ![]() ![]() |
The only problem that I see is that stainless is further away from aluminum in the galvanic table. What that means is that when they are in contact, a greater potential is created, and the lesser noble material, in this case Aluminum will corrode more readily. Not something that I would like. This would be made worse when surface areas are large. Many Defender owners go into great lengths to isolate small SS bolts from the aluminum.
How about making them from aircraft grade, preferably extruded aluminum, and hard anodized for the ultimate corrosion resistance? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 506 ![]() ![]() |
I can't see how they can be accuratley reproduced without a significant investment in press tooling and said tooling wouldnt last very long working with stainless.
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1646 ![]() ![]() |
i dont see a market for them.
original painted/ galv ones are plentiful on the used market aftermarket painted or galv plentiful for sale new as well we already have steel and alloy corrosion why would you add another steel to the mix |
Blue Blood Member Since: 14 Jun 2022 Location: Shropshire Posts: 132 ![]() ![]() ![]() |
These are all good solid point. However I can’t help but wonder where the steel comes into contact with bare aluminium. The upper part has a foam seal on above and the tubs are painted. So other than bolts /rivets joining I am not sure where the interaction would be?
Also speaking to the fabricator I think he said the design might need to be slightly modified (I’m assuming he is talking about the bump). But thanks everyone so far for feedback it’s good hearing peoples thoughts and opinions and knowing if there are any potential areas to consider/improve 😊 |
