![]() | Home > Series Land Rovers > My leafers |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10902 ![]() ![]() |
Seb it is ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 ![]() ![]() ![]() |
Well Seb turned 52 today. 😁 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
2011 110 USW
I keep tinkering with my series trucks. Due to a change in circumstances I've now got a bit more cash to throw at them.
Today I swapped around and fitted various lamp lenses, so the 88" now has a full set of original spec lights (still got to get headlights and backings), as does my cherrypicker. "Seb" has also gained a couple of genuine lenses. Some of them were un-branded repros which have faded pretty badly, so now it has some more colourful ones on with proper badging. The difference in quality is obvious. I also re-attached the cherrypikers sill panel to the sill and test fitted, just got to get all the nuts and bolts so it can be re-fitted. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
The bulkhead has now been repaired and painted for the 88", and the 1 Ton IIA is still getting plenty of use.
Out in the mud
Some work on the 88" over the past few months.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
2011 110 USW
First bit of Atlantic green on.
No, it was an SEB special colour, although they did specify it on some (not all) of their land rovers. It was also used on the 1998 heritage vehicles. 2011 110 USW
I see now, thanks for the info
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 910 ![]() ![]() ![]() |
Forgive my ignorance, but I assume that SEB ordered the vehicles in Bronze Green and then painted over that on the exterior? Hence the two-tone bulkhead? Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
In the early days they did order in DBG, some were run in that colours, some were over painted in beldene green. Mine was ordered in Beldene Green, but the colour scheme changed in 1966 so it was repainted in Atlantic green whilst still quite new, indeed it may never have worked in the dark green scheme as we didn't find any trace of signwriting on the outside. 2011 110 USW
