Home > Puma (Tdci) > Re-Mapping Advice. |
Minch90 Member Since: 15 Sep 2017 Location: Gloucestershire Posts: 236 |
Been a very happy driver of a BAS remapped 2.4 for a few years now, Pete from BAS is a legend. I have the standard exhaust (until it falls off then I’m off to Demand as well), but have the Nuggetstuff intake mod. Can defo recommend BAS as I’m sure many others will. 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround |
29th Jan 2024 11:58am |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 542 |
Can only comment on mine which is the 2.2and you have to have it mapped to clear the dpf function and associated temp sensors when you fit the 3 inch demand system..
I used bells auto services and got the stage 1at the same time.. I think that gives about 150hp, which I find plenty.. While I was there I got their intercooler and hoses.. A well made bit of kit.. Its been running sweet as a nut👍.. And I hope I'm not tempting fate😂.. I've got a picture of the intercooler been fitted.. I modified the bracing to the slam panel just to make sure it cleared the larger intercooler.. Click image to enlarge Click image to enlarge |
29th Jan 2024 12:05pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2048 |
As others have said, best to have a chat with Bell auto services https://bellautoservices.co.uk/
They have a great upgraded intercooler ( I have one, as do many other members on here) and silicon hoses etc. BAS are also well known and respected for their defender MAPs ( 150 or 165 BHP for the 2.4) , again many members have a BEL map. The great thing with their maps is you can have a version that provides a tool that you can use to revert your map back to standard, then reinstate the enhanced map whenever you want. The tool also provides great diagnostics for the defender. The key to having any map is to be confident that your engine has been well looked after and well serviced over its lifetime and that servicing is continued or done more frequently. Noting your insurance will need to be notified and that can incur extra cost and limit the number of insurers that will cover your vehicle. Having said all that you really need to think on whether you actually need a MAP at all. If your vehicle has performed well for your needs so far then what is the advantage ? It’s so easy to go down the route of “ I have an enhanced exhaust so why not an enhanced Intercooler, hoses, intake, airbox, then MAP, EGR delete, Cat delete etc “ and before you realise you have spent a couple of thousand pounds. |
29th Jan 2024 12:16pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20466 |
Alive for me. Really pleased, it will sound just right and will last. No Guts, No Glory.
29th Jan 2024 12:31pm |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 899 |
For an intercooler I can recommend AlliSport. I’ve had two without issues, but I know others have experienced some welds splitting. I think there was a rogue batch a time back. PWR are also very good.
For re-mapping, I would certainly go to a Defender specialist. I’m a fan of José from Td5INSIDE/PerformanceINSIDE. He’s mapped both my Td5 and 2.2. The 2.2 has an AlliSport intercooler and a slightly freer-flowing exhaust, but that’s it. José has also recently helped me out when I was stuck with a failed head gasket in Portugal, so I can vouch for him being a top chap. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
29th Jan 2024 1:36pm |
Learningasigo Member Since: 30 Nov 2023 Location: Midlands Posts: 28 |
Out of curiosity what sort of MPG gains do people get with a remap and intercooler?
I comfortably sit at either 26/27MPG in my stock 2.2. But I do drive gently and normally cruise at 60/65 on the motorway. |
30th Jan 2024 8:36pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 917 |
Intercooler: either BAS Hi-flo or alive ultimate
Remap: Either BAS or Alive and from your description a 150 map will do if you are not looking for looots of go. Although it is the higher power / torque gains that would see the reward of the bigger exhaust. As above IMO while you are in there if you change the intercooler you might as well do the hoses but for a 150 map you don't have to change anything. It'll work with everything stock it's up to you, It's a slippery slope to keep swapping bits and have the fun map Both alive or BAS can do you a tool so you can remote map it yourself or else you can go visit them or one of their agents to have it done for you. Both Gary (alive) and Pete (BAS) are really nice chaps to deal with. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
31st Jan 2024 5:29am |
With both Alive and BAS you know you can rely upon them, I have the former, but both are the two leading companies imo. No Guts, No Glory.
31st Jan 2024 5:21pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8077 |
i have a had a few.
Alive did my softop 2.4tdci and supplied an intercooler at the time. I found it quite a harsh map, nothing nothing everything style. Pete at BAS mapped my 2010 2.4 at 20miles and i fitted an Allisport intercooler at the same time. 105k on it now, 20% towing over its life. mixed lightly loaded 32mpg, recently with allisport airbox much better on a long run, avg for life 28mpg. Pete mapped my 130 2.4 at 60k goes well currently on 80k. BAS intercooler fitted. Pete mapped my 90 2.4 recently too will sort an Allisport intercooler for it or a BAS one in due course. So BAS for remaps gets my vote 110%. intercoolers, i have had 6 Allisport ones and one BAS one and one ALive one, all performed, none of them had any problems. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
31st Jan 2024 9:55pm |
