Home > Puma (Tdci) > Turn the key, momentary delay before starting. |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 896 |
Sticking contact/relay? Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
28th Jan 2024 7:55pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20348 |
Starter getting a bit tired, I have had a similar event happen a few times but seems to still keep going.
I wouldnโt worry too much unless it stops starting all together. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
28th Jan 2024 7:58pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4209 |
Not sure, could be I guess. Are they any that could be replaced as a matter of course for not much money? 2007 110 TDCi Station Wagon XS |
28th Jan 2024 8:31pm |
Hope it lives on. I read changing the starter is a ball ache. 2007 110 TDCi Station Wagon XS |
28th Jan 2024 8:32pm |
Most things to change on a Puma are a pain.
Any time Iโve had any issue, itโs always been a loose ground or battery clamp(s) loose. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
28th Jan 2024 8:37pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2038 |
Immobiliser ?
29th Jan 2024 12:14pm |
Could be, maybe the key wasn't detected momentarily? I don't know how I would test for that though. 2007 110 TDCi Station Wagon XS
29th Jan 2024 1:40pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 735 |
Ignition switch signaling it's about to go kaputt?
30th Jan 2024 2:46am |
Fob battery getting low can cause odd things to happen. $W33T $0U7H3RN $UG4R
30th Jan 2024 9:19am |
Ignition switch had crossed my mind. I don't think it's low battery as it sits on a Ctek for 99% of the time, plus when it did start to turn over the starter sounded lively. 2007 110 TDCi Station Wagon XS
30th Jan 2024 9:45am |
I meant key fob battery the alarm plip one. $W33T $0U7H3RN $UG4R
30th Jan 2024 1:44pm |
dannyragsdale Member Since: 06 Oct 2022 Location: Eastern Highlands, PNG Posts: 40 |
I had this happening to me when my starter was on its way out. Lasted for about 6 months before it finally quit on me. I generally noticed it getting worse after the vehicle was hot. If i had to make a quick stop and turned it off, it would sometimes worry me that it wouldn't start back up. Replacing the starter is a pain and I even had it on a lift.
4th Feb 2024 8:44am |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 816 |
Replacing the starter motor isnโt as bad as you might think.
Removing a few coolant hoses from the top to give you eyes on the starter and then undoing it from underneath is the best approach. And definitely get some coolant clamp pliers. https://www.screwfix.com/p/silverline-flex...lsrc=aw.ds 2008 2.4 110 Utility Station Wagon XS. |
4th Feb 2024 9:33am |
And disconnect the battery first. To prevent any fireworks ๐๐ $W33T $0U7H3RN $UG4R
4th Feb 2024 9:22pm |
