Home > Td5 > Td5 rear axle breather
Register
Hi, hopefully a simple matter as I’m away from home.
Some overnight oil seeping onto the offside rear rim.
Lots of online chat about blocked axle breather being a likely culprit.
From my photo it looks like a push fit.
Can I ‘pull’ the pipe out and purge it somehow?
Thanks Everything's a hammer.
Post #1022824 28th Jan 2024 4:58pm
donmacn
You would need to give it all a good clean first, then if you’re lucky, pressing the red collar down, while pulling gently at the pipe at the same time, and it should come out. If you clean the end, and blow into it you should figure out pretty quickly if it’s blocked or not.
Whether that’s the most likely cause of an oil leak…. is another question. Could just be that a bit of movement at the drive flange has caused the seal/gasket to give up? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1022828 28th Jan 2024 5:26pm
Register
Donald,
thanks for responding, I hoped that would be the case, hopefully nothing major as I have a long way to go.
Pete Everything's a hammer.
Post #1022830 28th Jan 2024 5:29pm
The axle breathers are another feature of the more recent Defenders where "value engineering" has resulted in something almost entirely unfit for purpose.
Whilst you are investigating your breather it would be worthwhile locating the free end and making sure it is somewhere which doesn't get plastered in crud, like, for example, the rear nearside wheelarch.
Post #1022859 28th Jan 2024 8:14pm
Jabberwocky
Luxembourg
When you say rear rim, do you mean the wheel? I had what I thought was oil pooling in the inner rim of the wheel and then running down the tyre onto the floor. If this is what you have then check your brake calliper, I had a leaking piston and fluid was dripping off the calliper onto the wheel.
Post #1022872 29th Jan 2024 1:42am
Register
Thanks both for your input.
I’ll check both when I get to some hard standing.
Currently amongst the trees.
Post #1022874 29th Jan 2024 6:05am
Register
So, brake pipes and unions all good and found the end of the axle breather up in the NS wheel arch. Yet to remove it.
Doesn’t looked to be blocked.
Any other thoughts? Everything's a hammer.
Post #1022879 29th Jan 2024 7:59am
markb110
Take the breather off of the axle and blow air through it from a compressor or even a bicycle pump just to be sure
A previous owner may even have added a zip tie somewhere and pulled it up tight enough to crush the pipe mid way or it may have dropped and melted shut from the exhaust.
Post #1022904 29th Jan 2024 12:39pm
Register
Thanks I’ll take a look along the length.
Post #1022905 29th Jan 2024 12:44pm
landy andy
When I check diff oil levels, and have filler plug out, I also blow through the vent pipe to make sure it’s clear.
Post #1022959 29th Jan 2024 8:54pm
Register
Andy
Thanks up for anything rather that strip the hub at this stage. Everything's a hammer.
Post #1022995 30th Jan 2024 8:15am
Register
Not sure if it’s a good plan, but as I’m on road for a few more days and the weather’s fine, I’ve removed the breather from the axle casing.
Also removed the boost wheel centre. Not what you’d call clean in there. The rubber cap is showing it’s 20 years with a substantial split.
It s it worth plugging that with some dumdum, which I have with me, as there’s now no pressure in the casing?
Or am I flogging a long expired nag? Everything's a hammer.
Post #1023022 30th Jan 2024 3:22pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Leave it for now, replace next time you service that wheel. 👌🏻 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1023046 30th Jan 2024 7:27pm
Register
Thanks.
’Leave it for now’ I can definitely do. Everything's a hammer.
Post #1023087 31st Jan 2024 9:55am
geobloke
If the breather is difficult to get out of the axle you can just remove the axle filler plug and blow down the breather pipe Thumbs Up Whilst there, check for kinks in the line. The purpose of the breather is to allow for pressure release, if the breather is OK then it is likely that your axle oil seals and/or stub axles are worn.
When it comes to oil leaks a little oil goes a long long way, so just keep an eye on oil levels and brakes until you can get it repaired.
Post #1023099 31st Jan 2024 1:08pm
