Home > In Car Electronics > Tdci heated screen switch
Page 2 of 2 <12
Linds Hanson
Yes can't say I noticed if the switch had the key in the right position just tried the action whilst still in the bag.
Post #1022585 26th Jan 2024 3:34pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
I was referring to the OP:
22900013A wrote:
Just an update on this. Fitted the new switch and still no telltale so presumably wiring? Also the new switch locks in place like the rear heated screen switch, which is rather odd.
The internal wiring of both switch types is different. You probably wont damage anything but it wont work either. It's not just that one latches and the other doesn't.
Post #1022611 26th Jan 2024 6:03pm
22900013A
Well this gets more and more daft. Frosty this morning so popped the s reen on (worth a shot I thought), no light, oh well got out and scraped a bit of frost off so I could see out. Set off and after a few minutes flicked the wipers and the frost came off. That's odd I thought. The heated screen was on! I then noticed the telltale was now lit. I've tried it a few times today and it all appears to be working as it should, hot screen and light lit. Very confusing. A total failure is of course easier to sort than a transient fault. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #1022727 27th Jan 2024 5:56pm
22900013A
You really couldn't make it up...
 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #1022761 28th Jan 2024 12:53am
Martin
Site Admin
You’ve got a loose connection somewhere. The telltale is connected to the feed to the screen, no telltale = no power to screen.
The logic goes like this:
The switch sends a pulse to the timer unit. When it receives this, the timer unit sends an output to the relay coil if the engine is running. Relay outputs to screen and telltale. The timer unit sends that coil output for the timer duration (10 mins?) or until the engine stops or it receives another pulse from the switch.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1022819 28th Jan 2024 4:04pm
22900013A
Yes I get that. I only touched the dash end of everything so presumably it was the dash switch connection? As its currently working I suppose all I can do is keep an eye on it! 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #1022833 28th Jan 2024 5:44pm
Page 2 of 2 <12
