Home > Puma (Tdci) > Instrument binnacle wiring diagram needed
steveyorks
England 1993 Defender 90 200 Tdi CSW Barolo Black
Im hoping someone can help me. All my instruments works fine but they dont light up with the vehicle lights. Im suspecting a dried joint within the instrument binnacle itself. Does anyone have a wiring diagram for the speedo/ rev counter cluster? Its a 2009 2.4 Puma. Any help would be much appreciated as Id like to have a look myself rather then send it away.
Post #1021985 21st Jan 2024 9:13am
mata
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
I've shared the whole wiring diagram on my icloud for you, see below. Looks like you need page 21 where the connection from sidelights is shown on pin 25 of the connector onto the instrument cluster. Id start br probing this pin with the sidelights turned on.
https://www.icloud.com/iclouddrive/007TACg..._to_751062
Post #1022002 21st Jan 2024 11:07am
steveyorks
Thats fantastic thank you very much. Its interesting that I also have the ns side lamp not working after I had some paint work done on that wing. Seems coincedence to me so it may not be the actual cluster thats at fault as from what you say there is a connection between side light and cluster. So I have pulled the fuse to ns side light and its gone. Replacing that has also fixed instrument illumination. I feel a bit of a fool to be honest but I can live with that now my problem is sorted so again thank you very much and the wiring diagram will come in handy!
Post #1022041 21st Jan 2024 3:05pm
andy63
could I also say thanks for the wiring dig which ive taken the liberty of downloading..
I have a 2014 2.2l tdci 110. and ive not come across a wiring dig yet that seems to suit the vehicle, so I thought id copy yours and see if that is any better than my Hanes manual Thumbs Up
also nice to see the op got a result an his issue
Post #1022050 21st Jan 2024 4:13pm
mata
Great stuff , happy to help!
Post #1022076 21st Jan 2024 7:02pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Here you go: https://onedrive.live.com/?authkey=%21AMrv...9C85C7C171
by our member dgardel
Post #1022308 23rd Jan 2024 7:10pm
andy63
Thanks for taking the time👍
I'll have a browse through that lot as well..
Post #1022311 23rd Jan 2024 8:12pm
Check the connector is secure to the rear also, it’s been known for them to get loose or not be fitted snug.
Worth checking at least before investigating further, though you probably already have. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1022313 23rd Jan 2024 8:16pm
