![]() | Home > Puma (Tdci) > Transmission Noise / Issue |
theflyingpaddy Member Since: 21 Jan 2023 Location: Perthshire Posts: 2 ![]() ![]() ![]() |
Did you ever resolve this? Just spent the day doing discs, pads, bearings thinking I would solve the noise… only for it to be there still on a test drive.
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 ![]() ![]() ![]() |
Sadly not, I stripped and rebuilt the front axle on both sides and swapped the diff for an ATB from Ashcroft's.
The 2 pin diff that came out was actually in very good condition so definitely wasn't a diff issue. The noise is still there, albeit intermittent, and if I don't drive the vehicle for a week or so it goes away for 30-50 miles. Very strange! Nothing has fallen off yet though 😋 Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
Thank you!
Oh the joys. Why do we bother… |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Diff UJ’s looking okay? Wheel bearings? Many noises or vibration like issues can be related to the prop shaft and their components.
And unless the Props partially come off it’s not always easy to find a failed UJ bearing. The rearmost UJ on the rear prop closest to the rear diff, was the one that failed on mine. Sometimes the grease nipples vanish too and should be replaced asap if one is missing. You can run with just one prop shaft, to see if either is giving the issue but isn’t ideal other than to just check. You can isolate the rear diff by removing the rear halfshafts and rear prop as well, but you do need the handbrake drum bolted on even if the rear diff is off. You have 2wd then front or rear whichever, but is going to handle different and is only really something to keep you going on a very temporary basis. I swapped over this way when I replaced all my UJ’s on my props for GKN units, cuts down the work and did one prop at a time. Or you can replace them outright, factory props aren’t cheap, upgrade ones significantly more. You can check wheel bearings as well, but these are just a couple of ideas. Edit* Just saw you had the wheel bearings replaced. Is the exhaust rubbing anywhere? Chillin In The Backwoods🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
