Home > Puma (Tdci) > 110 TD4 2.2. 2013 Clutch failure ??
Borbarad
Germany 2013 Defender 110 Puma 2.2 SW Fuji White
Hi guys, now another failure. Now it is the clutch.
Engine runs smooth, no rattling etc.. Gears where all fine. but out of nowhere. When I pressed the clutch und tried to change gears, impossible /very tough to engage one. Limped just home.
However, when its off, with or without clutch engaged I can smoothly go though the gears no issue. When for example I place reverse, turn on and let the clutch, drives smoothly.
when I try to do the same and engine running, no chance to engage the reverse gear.
Any idea what the fault could be? Clutch disk?, Clutch Pedal, Zylinder…????
B
Post #1021045 13th Jan 2024 6:57pm
ickle
Any fluid leak from bottom of bell housing?
Post #1021047 13th Jan 2024 7:11pm
Borbarad
Nope. Zero, Dry as usual, No Oil whatsoever
B
Post #1021048 13th Jan 2024 7:20pm
Spring came out of friction plate most likely, especially if there is no sign of fluid leaks and clutch feels like normal from a hydraulic sense.
New clutch required. WeWillWin🇬🇧🇺🇸
Post #1021055 13th Jan 2024 7:56pm
ickle
As Above ^^^^
Outside chance it could be the master cylinder, remove cover & get someone to press pedal and look for disturbance in the fluid (bypassing seals / leaking into footwell)
Good luck & let us know what you find
Keith
Post #1021063 13th Jan 2024 9:38pm
nidge n
I had exactly the same symptoms on my 2012 110 2.2 last year. New clutch im afraid. I did the output shaft whilst everything was stripped down. Good luck
Post #1021067 13th Jan 2024 9:53pm
andy63
I had my clutch fail without much warning.. Maybe a few noisy gear changes now and again in the preceeding months but then suddenly just very difficult to engage any gear when the clutch was dipped..
When I took it out one of the springs in the friction mate just fell out of its housing.. The spring had a gouge out of iylt and part of the housing had been torn off.. You can maybe make it out from this photo..
Bottom left spring
Post #1021071 13th Jan 2024 11:18pm
andy63
Duplicated
Post #1021072 13th Jan 2024 11:20pm
Andy63 - Was that a LR clutch friction plate? WeWillWin🇬🇧🇺🇸
Post #1021074 13th Jan 2024 11:53pm
Ickle - That’s the one I had hoped it would be, on mine it needed replacing anyway so I did replace the MC. But in the end it was the actual clutch, which of course then included the new slave to be fitted too.
I have the;
Sachs Transit 4x4 clutch in mine with the Gen, later 2.2L Slave and Gen MC.
I do like this clutch, it has less slip, a little more heavy duty but not heavy.
I’m pleased with it so far. Thumbs Up WeWillWin🇬🇧🇺🇸
Post #1021075 13th Jan 2024 11:56pm
andy63
Yes, AFAIK.. The clutch was original.. On a 2014 registered 110 with around 48000 miles..
I've got another picture of the friction plate and the inside of the pressure plate.. You can see it had been rubbing.. The loose spring is the pictures is the 2nd spring(internal one) out of the plate..
I didn't think any of that would have been possible.. But obviously was..
I had fitted a redboost clutch servo shortly after buying it which may have altered things.. But I thought it was a simple 1:1 mechanism and couldn't alter the length of stroke🤔
Post #1021085 14th Jan 2024 7:03am
Not only possible but very common. Early Puma clutches were absolutely terrible, my 07 had (at least) three replacements under warranty in three years and fewer than 40k miles. I've subsequently fitted two more and have one waiting to be fitted, although to be fair the current one (genuine LR) has now done around 130k miles. The next will be a Transit 4x4 clutch, not a LR one.
Post #1021090 14th Jan 2024 10:05am
andy63
I had no idea...
The main issue for me was clutch fluid contaminating rather quickly..
Which I thought I'd try and sort at the time my clutch failed.. I had tried flushing the system when the servo went on but it was mucky again fairly quickly😒
I fitted a LOF kit when it failed.. It wasn't branded as heavy duty or anything like that..
I hope I'm not left regretting not doing a bit more reading/research, and asking for opinions🤞
Post #1021093 14th Jan 2024 10:50am
The forum has been much quieter on clutch failures in recent years which suggests to me that the more recent driven plates have improved, it remains however quite unusual for a modern high-speed diesel engine to have a sprung driven plate (rather than a DMF).
We should however probably be thankful that JLR/Ford opted for a sprung plate since, problematic as it may be, it is less problematic than the appalling DMF setup on the TD5.
Post #1021098 14th Jan 2024 11:11am
andy63
Ahhh dual mass.. I had the mk7 transit at the time ford were having issues with early failures.. Thankful that mine was never an issue.. I came to the conclusion at the time that the failures, were as much to do with the use the vehicle was put to.. And I suppose they eventually improved quality.. I'm Not sure if its, still as big an issue??
Post #1021107 14th Jan 2024 11:53am
