![]() | Home > Faults & Fixes (L663) > Squeak / rattle coming from engine on cold start |
Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 605 ![]() ![]() ![]() |
Mine had done 20k at 1 year old. Racked up a fair few motorway miles driving to Hove every weekend for the past year. All fixed now. Not sure of the exact issue but the tensioner was slack and belt was clean break as opposed to shredded as others the AA chap had seen. Had service due so they did that while it was in. Brake pads/discs and wheels all still plenty of wear left which was nice to know. https://instagram.com/bentheoandrews |
BrettMRC Member Since: 02 Jan 2024 Location: South West Posts: 24 ![]() ![]() |
Job was done today, idler & ancilliary belt replaced under warranty.
Shorty53 Member Since: 17 May 2013 Location: Lancashire Posts: 135 ![]() ![]() ![]() |
Mine (D250 2021, 12.5k miles) had the chirping noise after cold start. Also stop/start would fail. Needed a shut down to re-start the engine. Reported to the dealer, mid March before they could take the car in for investigation. Called LR assist and the AA arrived within an hour. Diagnosed belt tensioner pulley (he had seen several others). I was about to take the caravan away for the weekend. He advised against that and arranged a loan car (with tow bar) with LR assist. Drove to the dealer and drove out with a Disco 5 X Tech HSE loan car with 15 miles on the clock. I would be happy to keep that car for as long as necessary.
As you would expect mine was repaired within a few days. New belt tensioner and belt. Stop/start was resolved with a new battery. All under warranty. Excellent response from LR assist and the JLR dealer. |
Aaaaaaaand the squeak is back. Belt/tensioner not gone again (yet). Luckily booked in for replacement suspension arms on Tuesday so they're going to have another crack at it. https://instagram.com/bentheoandrews
Not ideal!
How many miles since the change? |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 ![]() ![]() ![]() |
Yep I've had two fitted, the 1st one was done as a recall at around 9k miles and it failed at 14k miles. ![]() ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Less than 1000. ![]() |
Hopefully the same with mine. I do love my truck but it's becoming a bit like ![]() |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1115 ![]() ![]() |
Mine has started squeaking again when cold.
Out of warranty now, so has anyone got a part number for a new tensioner? 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
Seems that the part number is LR158323. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Deleted. 2021 Defender 110 X-Dynamic HSE D300 MHEV
...and the squeak is back.
![]() Booked in for early March to get it looked at, along with some other odd noises. |
